09-13-2011, 08:33 AM | #1 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| 8* vp chubs and knuckles for xr10
Ok, I see that I need a set of new outer shaft for my 300 that are converted to xr10, but can I use the aluminum chubs that axial makes, or is there an advantage to the vp ones. Also, am I better off using the vp xr10 knuckles, rather than stock aluminum ones? Once this conversion is done, do you just go with axial wheel hexes? Any help would be appreciated. |
09-13-2011, 09:26 AM | #2 |
You have to run the VP 8* Knuckles that are designed for the AX10, and run AX10 stubs on your super 300 cvd's. The C's are all basically the same. You still will need to run the hexes that have been drilled out for the super 300 shaft.
09-13-2011, 09:48 AM | #3 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
the c's are all not the same, the VP 8 degree c hub sets have the 8 degree king pin angle as well, the set requires both chubs and knuckles to work. they will not work with stock c hubs. just saying
09-13-2011, 10:39 AM | #4 |
I meant all 8* Cs should work. I would suggest running both the same manufactures parts to avoid potential issues with tolerances.
09-13-2011, 11:48 AM | #5 |
| Got it!
I need the ax10 vp chubs and knuckles, not xr10. When i said stock earlier i meant stock axial not berg!
