11-21-2011, 10:27 AM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Fountain
| Can I use these RC4wd wraith axles
Looking to get better steering angle and wondering if I can use these axles and/or what need to be modded to make them work? Rc4wd Xtreme Velocity Drive (XVD) for Axial Wraith [z-s0356] - $34.99 : CKRC Crawlers, RC Rock Crawlers I could not find mention of them via search |
11-21-2011, 01:03 PM | #2 |
In a berg? Doubtful.
11-21-2011, 01:06 PM | #3 |
any idea why? wrong lengths? the bearing should be the same as they use the same knuckles I can weld or mill the shafts I just need a U joint with better steering angle. if I can find just the joints I can cut and weld the current shafts I have onto them an just machine them to size etc.
11-21-2011, 01:21 PM | #4 |
11-21-2011, 01:31 PM | #5 |
11-21-2011, 01:32 PM | #6 |
I would also be worried about that area of smaller OD being a weak point...
11-21-2011, 01:42 PM | #7 |
Just ordered a set to see if I can make them work, I had to order some other parts anyway, if it works, it sure beats $145 for the super 300's.
11-21-2011, 01:44 PM | #8 |
The quality of those shafts will be nothing like the Super300's. I have beat on the 300's in my berg and never had a problem from them...
11-21-2011, 01:54 PM | #9 |
Rock Crawler Join Date: Jun 2009 Location: vacaville
If money is the problem why not try these half the price of 300s and they look to be really nice. http://www.rccrawler.com/forum/axles...ml#post3381324 |
11-21-2011, 01:59 PM | #10 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
You will also have to use XR10/wraith C's and knuckles. Otherwise you won't be able to get the pins in the CV to line up with the kingpins on the knuckle. If you wanted to go to that effort, I'd use the axial brand uni's, atleast they have been tried and tested in the XR10 and are not known to shatter every pack like the RC4wds. Kieren |
11-21-2011, 04:30 PM | #11 | |
11-22-2011, 12:02 AM | #12 |
I suggest trying a store of better reputation that also has them in stock. RPP hobby comes to mind. Also I believe the 'CV' joints still change speed throughout the cycle as they are essentially a mashed up uni. The only joint that is truly constant velocity is the double carden (uni) joint. Kieren |
11-22-2011, 01:21 AM | #13 | ||
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
I would agree that the Axial ones would be a better option but require you to cut and weld them together with a berg inner. | ||
11-22-2011, 03:06 AM | #14 |
Doing the C's and knuckles would be nice as then I can set the caster angle of choice. Seen a few in the build threads.
11-22-2011, 06:45 AM | #15 |
