Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Coming SOON! 1 Piece Rear Delrin Tubes...
Old 07-15-2012, 07:40 PM   #1
Chris_The_Battery_Man's Avatar
Default Coming SOON! 1 Piece Rear Delrin Tubes...
This is something I have been wanting to do for a while, and now have a donor rig to use as my test dummy.....
I whipped out a proto this evening to see how it will work out.
It uses a snap ring to keep the bearing in. Outter diameter is meant to utilize D_Lux lower link mounts. Much lighter than stock!
Sorry for the crappy finish, this one was a real quick proto....
Pm me for more info. I will be working out the machining kinks, and then announce a price/date....
Chris_The_Battery_Man is offline   Reply With Quote
Old 07-16-2012, 02:50 PM   #2
Default Re: Coming SOON! 1 Piece Rear Delrin Tubes...
SWEET!!!!! Message sent!!!
jcboof is offline   Reply With Quote
Old 07-16-2012, 05:20 PM   #3
Good idea! I brainstormed for quite some time on bearing retention methods and I am making the same thing for the axles I'm building. Still waiting for the groove cutter to be made but mine will be 7075.
95geo is offline   Reply With Quote
Old 07-16-2012, 05:44 PM   #4
Do you have pictures of the tubes with shafts installed? I'm wondering how these work since the hex pin and hex typically rest very close to the bearing. It seems like the hex would get into the "flange" on the end of the tube.
ittybitty is offline   Reply With Quote
Old 07-16-2012, 11:35 PM   #5
I dont, but I can get some soon. With a wraith axle test fitted, and a honcho style short hex, it fits perfect!
Old 07-17-2012, 03:11 PM   #6
Im i missing something,are these one piece.
MR.VERTICAL is offline   Reply With Quote
Old 07-17-2012, 05:21 PM   #7
If I'm not mistaken, those use a "lockout" to support and retain the bearing. The main factor that makes this design superior to the "lockout" style is that the tube supports the bearing without a joint that is typically 2 screws supporting the bearing, axle and entire rear of the car. I'm actually suprized an idea as simple as this hasn't caught on yet.
I predict that this style of berg tube will be more common than the lockout style before too long. It's too simple, strong and light.
Old 07-17-2012, 10:10 PM   #8
Wanna get? Gotta want.
Erik D_lux's Avatar
The screws dont support anything at all.
Erik D_lux is offline   Reply With Quote
Old 07-17-2012, 11:56 PM   #9
What he said below. The ones I am working on do not require a lock out to keep the bearing from coming out. Instead, a snap ring. Not that something this minimal is really "Needed" but just another option. I like minimal and simple on my MOA rig. So if I had a berg still, I would like these on it. But I might be building a berg to test on anyhow, since I am coming out with some budget XR/berg hybrid stuff
Old 07-19-2012, 07:35 PM   #10
So I am going to make a couple sets as a "test" run, and if they turn out, I will sell them at a slight discount for people that want to test em out. So feel free to PM me. jcboof is in line already.... I can maybe do 3 sets???
Old 07-20-2012, 08:15 PM   #11
Intrested! Those look way sweet! Will they work with the dlux rear axle shafts?
Beest is offline   Reply With Quote
Old 07-20-2012, 09:39 PM   #12
binaryterror's Avatar
2 screw holding my cap on my CKRC tubes is safer than 1 snap ring in a groove.
binaryterror is offline   Reply With Quote
Old 07-21-2012, 02:17 AM   #13
TSK
Shelf queen
TSK's Avatar
I'd definitely like to try these tubes out once I get some experience with a berg, looks like an innovati e option.
TSK is offline   Reply With Quote
Old 07-21-2012, 01:45 PM   #14
Unfortunately your still only trusting an e clip to hold your shaft in even with a lockout. I think the snap ring will be just fine.
klabeaume is offline   Reply With Quote
Old 07-21-2012, 01:57 PM   #15
X2!
The snap ring design really doesn't scare me at all, as long as the groove does in fact stay nice and square. If the groove gets worn a bit and gets v-shaped, it might be a problem. But honestly, how much side to side load gets put on our axles??
Old 07-21-2012, 02:37 PM   #16
Do you really need a bearing in there? I'm running full delrin rear tubes without bearings. For one complete season, and so far no slop has been produced.
Without a bearing, it would be easier for sure.
tarmo120 is offline   Reply With Quote
Old 07-21-2012, 03:41 PM   #17
TSK
Shelf queen
TSK's Avatar
So what supports the axle shaft? The shafts just spins directly in the delrin tube? What keeps the axle shaft from falli g out of the tube?
Old 07-21-2012, 04:25 PM   #18
Again, I maintain going against the groove at all times
Just the fact that you're comparing something I would make against a CKRC product is offensive in itself.
I tested a tube with a lip that was machined too thin by putting a shaft in it, with the snap ring in. I then held the tube, and beat the inner shaft on my bench. The lip was WAY too thin.... It was a blem. But I figured I would see how much force it would take to break it. I was able to beat on it pretty hard before it broke. WAY more than you would ever get from a crawler. So with the thicker lip, I am sure you wont have issues. I am confident that the snap ring will work fine. And just as klabeaume says, you'll have just as likely of a chance that the e-clip will fail on the axle shaft itself, as the snap ring failing.
Are you talking about rear tubes? I would be really surprised if you werent using bearings in the rear... Never heard of someone doing that....
I know you dont need one on a tube that has the bearing hole drilled, and you slide a lockout over that tube.... But then you need a bearing at the very end, behind the Hex.
Not running a bearing is a horrible idea. You would wear out the delrin. I cant see you being able to do that, and not having a lose shaft. Then how would you keep the shaft from sliding out?
I dont think they will honestly. I believe his shafts use a 12mm OD bearing. If I can make a set to 14mm OD, and have Erik make some 14mm mounts, then I will DEFINITELY be making larger ones to use the bigger 12mm OD bearing. That is a way easier bearing to get for the 6mm shafts anyway. But it will really depend. I have talked to Erik about either making some with a larger hole, or selling me a batch with a smaller hole so I can mill em out to fit. Time will tell. The 13mm tubes MIGHT work.... I thought about making a set and drilling the hole for a 12mm bearing, but .5mm wall is a bit scary
Old 07-21-2012, 04:54 PM   #19
cool idea Chris....just when you think you've seen it all...
bquin is offline   Reply With Quote
Old 07-21-2012, 07:27 PM   #20
These are very cool. I really like the idea. I am struggling was struggling with the the idea of servicability by ditching the lockouts but then it occured to me that you can probably service a lot by removing the snap ring. Cool stuff.
RickM is offline   Reply With Quote
Coming SOON! 1 Piece Rear Delrin Tubes... - Similar Threads
<<< Delrin Rear Bully Tubes >>> Chaotic Crawlers Axles, Trannys, T-case 177 04-27-2012 06:54 PM
~Delrin Rear Bully Tubes~ 53 willys RC4WD Bully 81 09-28-2010 01:14 PM
