Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Berg viper1 links
Old 05-15-2013, 09:31 AM   #1
Question Berg viper1 links
Ok i have an older enroute berg 2.2 kit that im going to put a ugc viper 1 chassis on and would like to know if there is a set of upper and lower links that will work or will they have to be custom made.
Thx for any input
Blackcloud is offline   Reply With Quote
Old 05-15-2013, 09:37 AM   #2
Default Re: Berg viper1 links
I would check dluxfab.com they sell links for the viper chassis! I would ask him if his will work!
huskerfan406 is offline   Reply With Quote
Old 05-15-2013, 10:48 AM   #3
Checked dlux he only makes them for the viper2 chassis
Old 05-15-2013, 10:57 AM   #4
I've run a V1 and V2 viper.
They really aren't that bad to make links for. Pretty straight forward.
My guess is you are looking for Titanium links, correct?
I'll have to check when I get home, but I might have a used V2 that I would be willing to sell...
bigstu is offline   Reply With Quote
Old 05-15-2013, 11:08 AM   #5
Wanna get? Gotta want.
Erik D_lux's Avatar
If you ever need anything or have a question, you should ask me directly. PM or email works best.
I am not sure of the differences between a V1 and a V2. I will see if I can figure out what the difference is in links.
Erik D_lux is offline   Reply With Quote
Old 05-15-2013, 11:16 AM   #6
The V1 links need to be a few mm shorter to work with the V2 so you would need a set of V2 links that are a little longer. You could either have someone like Erik build them that way, or use different rod ends to gain length where needed.
I've also seen some guys use the links offered by Crawler Innovations since they are easy for most people to modify themselves without many tools.
ittybitty is offline   Reply With Quote
Old 05-15-2013, 11:17 AM   #7
Just found this for the V2 links...this was on an XR though.
Originally Posted by articzap View Post
Okay so I went and measured my links for you guys. Bare in mind, these are measured on the truck, with a grade school 12" ruler. Also note my front upper link mount is vp and spun backwards for a longer front link.
Front Lower - 4 7/8"
Front Upper - 4 5/8"
Rear Lower - 5 3/8"
Rear Upper - 4 7/8"
And DickyT said this...about his Berg setup...
Originally Posted by DickyT View Post
Erik does great work I am running custom bent DLUX lowers on my Viper II. They are the same I used on my Viper, I just cut a few mm off the fronts to get the wheelbase legal
Old 05-15-2013, 01:36 PM   #8
Fifth dimension
Crawllife's Avatar
DT is a huge help with viper stuff. Erik is more than capable of getting the links done right. He does all of my links.
Crawllife is offline   Reply With Quote
Old 05-15-2013, 02:04 PM   #9
Erik texted me, I just got to a computer and was looking for that to post.
Thanks Ryan
If I recall I cut about 3mm of threads (1.5mm per side off of the front links) off of my Viper Links for my Viper II. So Viper 2 links with the rod ends twisted out 1.5 turns from fully screwed on will work just fine.
If you don't, I do! In a few different flavors from early prototypes, to production, to the Viper Lite (full CF - 52 grams with all alu hardware except links which I used SS)
DickyT is offline   Reply With Quote
