11-14-2013, 09:17 PM | #1 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
| broc's pit/bulldog mix
ok thanks to all the venders that made this possible and my wife for not leaving me ...thanks to chassi cut customs for well basically a berg in a box you might of heard of this before well here we are tease i know... Last edited by bronc4now; 11-14-2013 at 09:32 PM. |
11-15-2013, 06:49 AM | #2 |
Rock Crawler Join Date: Mar 2010 Location: Happy Top
| Re: broc's pit/bulldog mix
Looking forward to seeing what you come up with. The berg in a box is a sweet set up.
11-15-2013, 01:53 PM | #3 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
Hurry up...
11-15-2013, 08:57 PM | #4 |
| Re: broc's pit/bulldog mix |
11-18-2013, 05:26 PM | #5 |
11-19-2013, 12:08 AM | #7 |
Looking good man.. But your rear lowers are on backwards.. Small bed should be axle side. Like this: |
11-25-2013, 11:19 PM | #8 |
Ok so ive been working on my rig but my computer or photo bucket started acting stupid so I can't post picks right now im bummed .any way I made my steering link solid steel rod and mounted up my tires and checked my width and I was I lot wider then I was expecting ..im running vp slw wheels .7 wide and voodoos stock. .ok so from outside tire to outside tire im 11.625 front and 11.125 rear lookin back at in old post looks like 10.75 to 10.25 Is more normal .. So maybe im just doing something wrong but vp website says berg should be at a smaller size but they also say wheel to wheel not tire? Whatever it is im going to get some .225 to bring me in some I know .7 wheels is kinda narrow and I wanted 1.0 but made a mistake and bought the wrong ones in a drunk shopping spree |
11-26-2013, 07:32 AM | #9 |
RCC Addict Join Date: Aug 2013 Location: South East
No worries..... That is easy to fix. I am happy running Shift Hubs front and rear. I am right at 11 front and 10.8 rear.....
12-05-2013, 08:49 PM | #10 |
ok fixed my photo problems so were back up.. I made my front steering link and lipo mount rr copy my caster is set forword (+) a lot more then im used to ..ill have to see what works might have to go back some . moving my caster back should help here i think maybe way (-) would be better any way its coming along great im going to swap to micro deans plugs then she ready to turn some thead |
12-06-2013, 07:18 AM | #11 | |
| Re: broc's pit/bulldog mix Quote:
.475 front and rear ..In at 11" front 10.785 rear .. I'll try and test like this for a bit.. | |
12-06-2013, 08:11 AM | #12 |
You need CASTER...BAD Your c-hubs should be rotated back from vertical. |
12-06-2013, 08:35 AM | #13 |
Ya when I set my c hubs up they were off the links so I thought it was vertical as is the servo but ..ya I'm testing definitely needs pos caster ..at least I know it's only going to get better ..
12-06-2013, 08:42 AM | #14 |
Do you have a pic from the side of the rig with one front tire off? If you could pull the tires and sit it on the table and take a pic from the side that would be good. If not...just pull 1 tire and put something small under the front axle to keep it level and snap a pic that way.
12-06-2013, 08:58 AM | #15 |
Yes a side shot would help...... Press down on the rig and let it rebound natural as well. I just emailed you some reference photos as well. We will have you kicking it in no time....
12-06-2013, 09:15 AM | #16 |
You keep incorrectly referring to what you have as positive caster and saying that you need negative caster. It's the other way around. |
12-10-2013, 08:33 PM | #17 |
heres my side pic after i moved it back i think im good as it sits..being compressed and let go its about 10* caster and it helped my steering too..sorry didnt feel like taking wheel weight off for pic.. all wired in ready to hit some rocks can u tell i like pics ok next update i should be running then ill make some adjustments to springs and whatnot ... Thanks again barry at classicutcustoms for all the help and info o need some body panels ive seen some cool ones Last edited by bronc4now; 12-10-2013 at 08:36 PM. |
12-11-2013, 07:07 AM | #18 |
I run way more caster than what you just changed it to.
12-11-2013, 08:32 AM | #19 |
12-11-2013, 09:54 AM | #20 |
Your rig is getting there. Looks a bit too tall to me in the photos. Try laying the shocks down or shorten the some how. I would drop you upper links down a hole or two as well. Try and get you uppers parallel with the ground.
broc's pit/bulldog mix - Similar Threads | ||||
Wraith lost in the mix | xgerstandtx | Axial Wraith | 25 | 03-10-2013 12:27 PM |
Magnets in the mix. | Willy Smellson | Electronics | 6 | 02-23-2013 10:40 AM |
Indoor Crawling Pit At Bulldog Raceway In Radcliff, Ky | sittinheavy | Kentucky | 0 | 02-23-2010 07:30 PM |
Just a little mix of things | run2jeepn | Videos! | 5 | 03-26-2007 06:19 PM |
