11-08-2016, 12:00 PM | #1 |
Newbie Join Date: Aug 2016 Location: Chelsea
| Knuckle Weight
About how much weight should be used on the front knuckle weights? Installing on an MOA Comp rig with carbon fiber 2.2 wheels. i'm looking to swap out from an old setup with wheel slugs.
11-08-2016, 12:27 PM | #2 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Knuckle Weight
depends on the car and overall weight of the car. I dont have enough information to answer your question. Also its a matter of preference. I think I'm runn some where between 6-8oz on each knuckle.
11-08-2016, 12:38 PM | #3 |
| Re: Knuckle Weight With electronics, motors and old slug wheels, a shade over 4lbs. Berg Pro comp with Sudu chassis. Dlux delrin tubes.
11-08-2016, 12:54 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Knuckle Weight
My berg MOA weighs 4lbs.10oz I'm running close to 6oz of KW on ea side... I feel I could probably reduce some KW but haven't and don't plan on it anytime soon.
11-08-2016, 04:11 PM | #5 |
| Re: Knuckle Weight
How much weight do you have in the wheel weight slugs? I'd start there with amount of knuckle weight. The feel of the car shouldn't change a whole bunch that way.
11-08-2016, 07:53 PM | #6 |
| Re: Knuckle Weight
Like Curcal said, weigh your wheel with slugs, tire & foam. Then weigh you CF wheel with tire & foam the weight between the two weights = KW. 10oz wheel, slugs, tire & foam (wheel on rig) -4oz CF wheel tire & foam = 6oz of KW. |
11-08-2016, 11:15 PM | #7 |
Pebble Pounder Join Date: Nov 2012 Location: Bavaria / Germany
| Re: Knuckle Weight
At least as much that your balance is RTR with a forward bias.It can also be much more,that depends on personal preference and driving style
11-13-2016, 09:23 PM | #8 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Knuckle Weight |
Knuckle Weight - Similar Threads | ||||
wheel weight vs knuckle or axle weight vs creative weight distribution | tech712 | Axial SCX-10 | 16 | 11-04-2014 01:04 PM |
knuckle weight help | Japanwraith | Axial Wraith | 8 | 02-25-2014 06:11 PM |
knuckle weight | dodgeboy8888 | EnRoute Berg | 6 | 09-12-2013 09:54 PM |
