05-15-2009, 01:59 AM | #1 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
| Durga or Dark Impact for a Formula Offroad build(paddle tires) on 3-4s BL???
This will be bought used ,it will be a low budget fast basher Just being confused by the number of shaft driven over belt as a preference for higher speeds ... The Dark Impact is a lot cheaper too... Whats your thoughts on these??? Thank You!!! |
05-15-2009, 07:09 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
I'm thinking with paddle tires you'll want to go with the dark impact. not sure how well the belts on the durga are going to hold up to repeated shock loadings and the added inertia. however, I could be wrong. post pics when you do it, this is a cool idea. The only other advice I can give you is to keep it as light as possible to avoid breakage. |
05-15-2009, 07:42 AM | #3 |
