04-21-2011, 08:22 AM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| jebster's foff...maybe?
i decided i'm going to give this a shot. seems like there are so many possible configurations i might as well jump in. i've mentioned in a couple other threads i was going to use my very old (but runs fine) kyosho inferno 10. i'm going to stretch the chassis, gum up the diffs (100k grease), change up the steering (thinking about a solid link given the limited shock travel) and slap on some paddle tires. i do have a few questions: 1. is a longer wheelbase better, in general? i was thinking of going from 10.5" to 13.5" 2. if i went to 13.5" wheelbase was track width would be good? 11"? 12"? 3. what is the most common weight balance? heavy front? heavy rear? (when i stretch the chassis i can move the motor forward, back, flip it to be very heavy front, etc.) here are a couple pics of the starting point: |
04-21-2011, 09:29 AM | #2 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
Yes, longer is in general better. I think 13.5" seems to be the norm. Your track will be fine, you can always use your wheel offset to widen it some too if you need to. You probably want the weight bias to be more towards the front. Climbing hills, so you have less chance of a backflip. Remember, the 1:1 FOFF rigs have the engine up front for weight, so if you are stretching the chassis, stretch the back. The guys that are using solid axle rigs can adjust their link lengths to accommodate a longer WB, but with an IFS rig you're stuck with what you have, unless you adjust the chassis. Looking forward to seeing what you do with it! |
04-21-2011, 11:31 AM | #3 | |
by the way, is proline the most common paddle tire? | |
04-21-2011, 01:27 PM | #4 |
Newbie Join Date: Jun 2010 Location: riverside
From what I have read, Panthers seem to hook up best. I haven't had any personal experience, though.
04-21-2011, 01:45 PM | #5 |
Newbie Join Date: Apr 2011 Location: denver
panthers are great tires... i am running sand paws all around; but i think i want panthers in the rear at least. they are kinda soft but seem to hold up well enough.
04-21-2011, 02:31 PM | #6 |
i'll look into them. by the way, who makes those paddle tires that are staggered? looks like it could be a good option for the front wheels.
04-21-2011, 02:45 PM | #7 | |
but not sure that the nitro is going to be up for much crawling. When i build my FOFF im going to go for a slightly forward weight bias | |
04-21-2011, 02:56 PM | #8 | |
based on the inputs so far i think i'm going to swap the motor to be in front of the center diff to move more weight forward. | |
04-21-2011, 07:33 PM | #9 |
04-21-2011, 08:23 PM | #10 |
sand paws is the name. looks like proline has a set.
04-22-2011, 09:26 AM | #11 |
You're right. I was mistaken. It is proline
04-22-2011, 05:50 PM | #12 |
Quarry Creeper Join Date: Mar 2010 Location: canada
ive run sand paws and panther paddle tires up front. the panthers do hook up better but the sand paws turn better. i run panthers in back and sand paws in front.
04-22-2011, 06:09 PM | #13 |
that looks like a pretty common setup. that's what i'll be doing. spent last night tearing apart the inferno and cleaning everything up. also packing the diffs with a heavy-duty bearing grease to stiffen them up. i'll try to post some pics of how i plan on laying everything out soon. |
04-22-2011, 07:16 PM | #14 |
cant wait to see the pics |
05-15-2011, 10:05 AM | #15 |
a little bit of an update. torn down the inferno 10 and cleaned everything up. to flip the motor to run in front of the center diff i had to swap the front and rear diffs in their housings. luckily that didn't require any mods. to extend the wheelbase i used some universals i had left over from my venom creeper. i'm up to ~13.5 inches now. i also started laying out the chassis. i like to mock up things using some heavy cardboard. i have the main plate (sides will be bend up to reduce flex), servo mounting plates and vertical support plates (have holes drawn on them to lighten them up; will have screws from under the chassis and on top through the servo mounting plates). i also mocked up a solid steering link using some straws. the stock dual bellcranks were in bad shape and i wanted something able to handle some heavy hits. i know the solid link will cause some bump-steer but the front won't have much articulation so i think i will be able to live with it. so, i just need to pick up some T6 sheet and start cutting. here are some pics of the mock up configuration: |
05-17-2011, 05:14 PM | #16 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
love the steering link. not sure how long it will last though. |
05-18-2011, 04:53 AM | #17 |
05-18-2011, 11:32 AM | #18 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
Cardboard never looked so good!
05-18-2011, 11:58 AM | #19 |
05-19-2011, 12:06 AM | #20 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
loos like an interesting idea jeb i am thinking along the same lines only with an 1/8th scale kyosho turbo inferno buggy
