04-30-2011, 12:58 AM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Humboldt
| 32p spur/pinion questions
So FOFF looked like way too much fun not to build one right freakin now! I will be hitting the sand and gravel pits around here and want to go with the 32p for durability. So here are my questions: I've seen that 56/16 is a popular combo, so what brand's plastic spur gears seem to be the most durable? Part number? Any mods required for fitment? Finally, would it be worthwhile to go metal for the spur right off the get and forget about plastic gears? Looking to those of you out there who have the experience I'm trying to gain for some much needed info. Thanks, tbilz
04-30-2011, 01:10 AM | #2 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
Traxes gear are the way to go i started out with a 14/56 after running with Chino63 went to a 16/56 and hold on way fast |
04-30-2011, 08:33 AM | #3 |
Rock Stacker Join Date: Sep 2010 Location: Cedar Rapids
So 56/16 in traxxas, from what model, rustler/pede?
04-30-2011, 12:11 PM | #4 |
RCC Addict Join Date: May 2009 Location: In the warmth!
I just put on a Traxxas 54T with a RR 12T pinion. Faster than the Axial gear set but I want more. Gonna try a 14T pinion next or a 52 spur. Believe the spur was for the Jato. Last edited by Robotboy; 04-30-2011 at 07:04 PM. |
04-30-2011, 01:09 PM | #5 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I've used this one.... Associate NTC3 54 tooth - pt. #2266 Fits the Axial bolt circle. http://www.google.com/products/catal...d=0CDoQ8wIwAw# |
04-30-2011, 10:40 PM | #6 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
I'm a big fan of the kimbrough precision 32p gears. They bolt right up and are tough as nails, just make sure you're not ordering the traxxas specific gears. I'm currently running a 50t spur/20t pinion on 3s with my castle 1406 4 pole 4600kv and it's completely ballistic.
04-30-2011, 10:46 PM | #7 | |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
04-30-2011, 11:53 PM | #8 |
| sweet
I knew other people here wanted to know these same things. I appreciate the info from all who offered it. Got some unexpected money today that will soon be taking on the form of a kick ass foff rig. Time to get some air under the tires! Thanks again.
05-03-2011, 10:31 PM | #9 |
Quarry Creeper Join Date: Mar 2010 Location: canada
just switched from a 20/87 to a 18/54 32p. awsomeness. |
05-05-2011, 09:57 AM | #10 |
| http://www.kimbroughracingproducts.com/spur-gears.html part numbers 118 (50 tooth), 119 (52 tooth), & 129 (54 tooth)...and I am running a part number 115 (44 tooth) on one of my FOFF rigs BW |
05-05-2011, 11:20 AM | #11 |
Newbie Join Date: Jan 2008 Location: So.Cal
Are you running the 49 pitch pinion?
05-05-2011, 11:49 AM | #12 |
48 pitch don't handle my abuse level at all...I only run 32 pitch now for foff...and they hold up great. The part numbers I listed are 32 pitch gears.
05-09-2011, 03:20 PM | #13 |
Quarry Creeper Join Date: Feb 2008 Location: port jefferson station
how much of a difference will i see switching from 20/87 48 pitch to the 32 pitch gears? 5700kv cc motor on 2s currently.
05-09-2011, 06:40 PM | #14 | |
RCC Addict Join Date: Mar 2008 Location: SSF
54 / 18 = 3.0:1 ratio Around a 33% increase in speed. Switch to 3s for another 50% increase. 5700kv on 7.4volt is 42180 motor rpms. 5700kv on 11.1volt is 63270 motor rpms, 70000 at full battery peak. Your best spurs gear will be the machined ones. The molded ones always have a bit of eccentricity between the mounting hole and the gear pitch, makes for a wobbly spur gear. | |
05-30-2011, 06:01 AM | #15 | |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
05-30-2011, 07:00 AM | #16 | |
05-30-2011, 07:13 AM | #17 |
Thanks, just wanted to make sure I wasn't missing something important. the 68T is the smallest my LHS had so I grabbed a 20T pinion. That'll give me a 3.4:1 ratio if it fits. I just realized the brainfart I had, the spur is too big and won't clear the driveshaft, guess I'll need the smaller spur/pinion combo. Thanks.... |
