Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: best 100mm hole to hole shocks
Old 08-29-2011, 01:01 AM   #1
Default best 100mm hole to hole shocks
I'm looking for 100mm (4) hole to hole shocks. Anyone have and suggestions?
muddinscx is offline   Reply With Quote
Old 08-29-2011, 09:54 PM   #2
I'm using HPI MT2 aluminum shocks limited to around 100mm..
Hope that helps..
the_ghetto_rig is offline   Reply With Quote
Old 08-29-2011, 10:00 PM   #3
KEOSHO makes a "Velvet coated" shock 100mm hole to hole
From first hand experience:
they are so smooth
Regards Rick
v84x4 is offline   Reply With Quote
Old 08-29-2011, 10:28 PM   #4
Keep it real
Tanis's Avatar
Traxxas aluminum Big Bore shocks
http://www.tcscrawlers.com/Traxxas-S...2-p-17910.html
Tanis is offline   Reply With Quote
Old 08-30-2011, 06:27 AM   #5
Location: Taylors Falls just hanging with the MNRCRC crew.
X2...Of all the available shocks on the market at this time the Traxxas Aluminum Big Bores are going to be hard to beat.
Stormin2u is offline   Reply With Quote
Old 08-30-2011, 10:44 AM   #6
Are the shock shafts from the alum traxxas big bores different than the stockers from the slash4x4? Those noodle shafts gave up on me after a couple runs, granted it was in a go fast.
The kyosho velvets are indeed silky smooth!
Meatwad is offline   Reply With Quote
Old 10-14-2011, 04:44 PM   #7
I'm running the G-made 94mm with rustler springs.Super smooth no leaks over a year of hard crawling,they have ball mount tops which makes them easy to mont and free of binding, you can change the lower rod end to adjust to what ever hole to hole measurment you want, just my two cents.
Hacksaw707 is offline   Reply With Quote
