11-04-2007, 11:57 PM | #1 |
Rock Stacker Join Date: Jan 2005 Location: Toledo
| My WK Formula offroad?
Wheely King axles JR ST126MG servo K2-3L chassis, modified Masher 2k's on Axials Wacker body Brake line and threaded rod links Traxxas tranny Novak XBR 8.5 w/sintered rotor It sure is fun |
11-05-2007, 12:33 PM | #2 |
Rock Crawler Join Date: Feb 2007 Location: Bridgeport
It looks good too. What's your wheelbase now?
11-05-2007, 03:01 PM | #3 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
First thing that comes to mind is where's the paddles?
11-05-2007, 03:54 PM | #4 |
Quarry Creeper Join Date: Aug 2007 Location: Lumberton
looks freaking awesome to me. |
11-06-2007, 05:22 AM | #5 |
Thanx. Yeah.....about the paddles, I don't have dunes around here that I know of. The only decent sized sandy area I currently know of I can't use anymore because it is up for sale. The old owner used to let people ride dirt bikes and stuff on it but the real estate company that owns it now doesn't. I need to find a nice bashing area. The WB is around 13.5''. I was debating whether or not to cut it down to match the body, but I didn't want to give up its uphill stability. Last edited by viper7016; 11-06-2007 at 05:29 AM. |
11-06-2007, 09:58 PM | #6 |
Quarry Creeper Join Date: Dec 2006 Location: dot com
looks like fun. Would look better with four huge rooster tails. Get some action picks, And let us know how it holds up to brushless power.
11-07-2007, 01:41 PM | #7 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
Sweet .... Good to see a fellow WK formula offroad build |
11-07-2007, 09:19 PM | #8 |
Newbie Join Date: Nov 2007 Location: Vancouver, BC
I'm trying to do something a little like this. I've got a Mamba Max w/ the 5700kv motor on order. I need to lower the truck and stretch it so it is more stable as it runs around at 40mph. I look forward to seeing your run. SG |
11-08-2007, 04:42 AM | #9 |
Quarry Creeper Join Date: Oct 2007 Location: Ohio
Is that a stampede tranny?
11-08-2007, 09:37 AM | #10 |
It is a Traxxas Magnum 272 tranny that I took out of my rustler. I put all steel gears inside and switched to a 32 pitch spur and pinion.
08-07-2008, 03:41 AM | #11 |
Pebble Pounder Join Date: Feb 2006 Location: FRANCE
Do u have a link for steel gears plz?
08-07-2008, 04:40 AM | #12 |
They are the Traxxas gears for their VXL line of vehicles. You can go to their site and look at exploded diagrams for the part numbers. http://www.traxxas.com/products/elec...tler_views.htm |
08-07-2008, 05:47 AM | #13 |
Quarry Creeper Join Date: Oct 2007 Location: Sheboygan
Looks like you are using the traxxas yoke on the trans but what are you using for driveshafts and how are you connecting the drive shaft to the 6mm output shaft of the diff? I have a pede trans I am trying to put into a wk tuber.
08-07-2008, 09:35 AM | #14 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
I did a similar setup using an MFM chassis with Maxx shafts and a pede trans, works great! I like the lower link mounts on yours, where did you get the channel to make them? Or are they custom bent? Nice lookin' rig |
08-07-2008, 01:19 PM | #15 |
The axles are Maxx/pede hybrids. Maxx yoke and female shaft on the axle side, then a pede male cut off, stuck in the maxx and a screw going through the whole thing, and then a pede female on the trans side so it can still slide. The channel is 1/2'' from lowes. |
08-08-2008, 06:34 PM | #16 |
| Sweet I use all Maxx for the drive shaft ... The T-Maxx tranny used 5mm output shafts T-Maxx output yokes #4927X http://www3.towerhobbies.com/cgi-bin...?&I=LXDDT2&P=M Diff output yokes #4928X http://www3.towerhobbies.com/cgi-bin...?&I=LXDDS6&P=M Last edited by SnoopMaxx; 08-08-2008 at 06:37 PM. |
