07-20-2010, 12:10 PM | #1 |
Newbie Join Date: Apr 2008 Location: Orange County, Ca
| 13.5 to much motor?
I picked up a G-made R1 today. I have a 13.5 motor waiting to go in something. I was looking to build the R1 as more of a rock racer. Is the 13.5 to much motor or should I stick a 17.5 in it and gear it up some?
07-22-2010, 09:59 AM | #2 |
Pebble Pounder Join Date: Jun 2010 Location: belgium
just try it i have now a 13 T brushless motor in it i love it |
07-22-2010, 12:01 PM | #3 |
I put it in with a 12t gear. Should see how it runs tonight What gear did you go with? |
07-23-2010, 02:59 PM | #4 |
the one out of the box 12t pinion |
07-23-2010, 11:13 PM | #5 |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
the R1's portal gears are pretty tough ...... ive been using it and driving thru binds expecting something to break ...... i opened it up and the gears still look fine ..... im pretty sure that it can handle a 13.5T motor ...... have the shocks set up in sprung though so you have more compression play if you do plan to do some crazy jumps ....
07-26-2010, 10:41 AM | #6 |
The 13.5 is fun. But I need to turn the drag brake down in the Tekin. It does front flips if you let off the gas I'm going to change from droop to a spung set up. It's a nice mix of fun for crawling and a little bashing. |
