View Poll Results: R1 - Sprung or Droop | |||
Sprung | 9 | 37.50% | |
Droop | 15 | 62.50% | |
Voters: 24. You may not vote on this poll |
08-02-2010, 12:36 AM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: Malta
| R1 - Sprung or Droop?
Hi guys Now that a lot more are building and running the R1 i guess i can ask this question to get some feedback from your experiences. I'm running mine in droop setup at the moment, the only reason not to tip over at steep inclines while crawling. But noticed that it bellies out a lot then. Would like to hear from you guys, especially from people running it sprung not droop. Does it make a huge difference? Does it tip over easier? thanks guys Last edited by adrians3109; 08-02-2010 at 12:38 AM. |
08-02-2010, 01:09 AM | #2 |
is what ever works best where you crawl. i prefur a sprung setup as its easier to tune, much more control, ive found a lot less wheel hop and axle steer as well, and you arient draggin your belly on every rock try sprung and droop, note the pros and cons of each and use the setup that suits you and your rig best |
08-03-2010, 04:16 PM | #3 |
Newbie Join Date: Apr 2008 Location: Orange County, Ca
I built mine as a rock racer and have had both droop and sprung. It jumps alot better with a sprung setup. But it all depends on your driving style and what you are looking to do with it.
08-03-2010, 05:39 PM | #4 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
I dont have an R1 but I ordered 2 sets of the shocks and I'm gonna have one set sprung and the other droop. and swap them out depending on the situation
08-04-2010, 07:59 AM | #5 |
Rock Stacker Join Date: Apr 2008 Location: Virginia Beach
I have mine set up as sprung. I tried droop with my Boulder chassis AX10 and it just seemed to cause component clearance issues with the TVPs and the front servo. I imagine if you are skilled enough its great but I am not at that point.
08-04-2010, 08:19 AM | #6 |
| IMO drrop sucks on an ax-10, makes them verry unpredictable and takes a lot to get the suspension geometry and locations correct, a "skilled enough driver" would know how to properly tube his rig, there for being able to better drive it and have a better preforming rig, look at all the comp rigs out there, id say 95% are sprung.
08-04-2010, 01:20 PM | #7 |
thanks for the feedback guys....seems many are in favour of sprung setup. I just finished changing mine to sprung and even though i have not driven it yet it does not look too bad.....ride height went up by approx 1cm but wont be a flipping issue i think....its more of a plus to clear rocks. Ideally yes its best to have two sets of shocks i think so you can choose the setup easily. thanks guys |
08-17-2010, 12:53 PM | #8 |
Newbie Join Date: Aug 2010 Location: Nacogdoches
I also like sprung myself.
08-17-2010, 08:41 PM | #9 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
I went for droop. I like having a lower COG. on its first test run on the week end the car performed really well. Making some climbs that I thought it would have no chance of doing. Seemed to jump well too.(see my other post for picture)
