08-03-2010, 01:29 PM | #1 |
Newbie Join Date: Sep 2008 Location: United Kingdom
| Drivetrain problem with my R1...
...as title states, i have a drivetrain problem with my R1. Had it outside my house this evening driving around on some pretty tame terrain, certainly nothing that i thought should pose any challenge or cause any breakage. Was driving over a patch of rough grass that split our house & next doors & got bogged down a little. Managed to get out then noticed that the drive wasn't 100%. On investigation it seems to have lost the drive on the left rear wheel so it won't climb to any degree & the wheel can be spun freely whereas the other three remain locked. Before i start the strip down to see whats wrong, can anyone suggest what might be the problem? As i'm still a relative newcomer to RC. Cheers Paul. |
08-03-2010, 02:41 PM | #2 |
Sounds like you lost hex pin. Did wheel wobble when you spun it ?
08-04-2010, 12:27 PM | #3 | |
Strangely enough though, when i picked her up the left rear wheel was back to normal but the two fronts were spining, not completely freely but still moving with resistance while the others were locked as they should be. So i started to strip the left rear as thats where the problem started, then when i found i didn't have the correct tools i built her back up again, only to find all wheels were now locked as normal except the right front which can now be moved slightly. Can anyone make any sense of this?!? Failing that i think it'll have to be a strip-inspect & rebuild job. Cheers Paul. | |
08-04-2010, 01:14 PM | #4 |
| Give that man a cigar!! I hadn't lost the left rear stub axle pin, it was never there!! I removed the other three wheels & all were missing! What i can't understand is how the gu i bought it from managed to tighten the wheels enough for it to drive without these in place??
08-04-2010, 03:46 PM | #5 |
Quarry Creeper Join Date: May 2006 Location: Pirkkala, Finland
Drivetrain problem here too... But a bit different. My rear driveshaft keeps on popping out from the tranny side. I have Mabuchi 540 -sized motor in the truck now and using 3S lipo. Currently waiting for 3200kV brushless motor, so I can't even imagine what happens with it! :( I'm a bit disappointed for the shafts, but maybe I should just get Junfac/MIP replacements. |
08-04-2010, 04:14 PM | #6 | |
There few a ways to prevent that happening. 1. Check the wheel nuts often 2. Clamp on hexes 3. New wheels nuts with a drop of lock tight | |
08-08-2010, 08:37 PM | #7 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
The stock hex pins seem to be too hard/brittle. I managed to break all 4 during the course of my first battery charge. They were fine till it fell and landed on the side of the wheel. I always bring spares and replaced them as needed. So if you think they might have not been installed or fallen out somehow, I bet they broke in 3 pieces like mine did and you lost the pieces during the removal of the wheel. |
