08-18-2010, 10:14 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
| Gmade R1 Chassis Dimensions???
I was curious if anyone could give me a couple dimension from the R1 Chassis. Need to know, outside to outside hole location for skid/bottom chassis inside to inside hole location for skid/bottom chassis Also height of the radio plate/battery plate from the center skid to make sure I'll have clearance there as well. I'm looking at possibly using this chassi for a build and seeing if it will fit the currently tranny I plan on using. Thanks Chris |
08-18-2010, 04:22 PM | #2 |
Quarry Creeper Join Date: Feb 2010 Location: muskegon
| I just pulled this off Gmades web site kinda easy to find if you use the search bar |
08-18-2010, 09:22 PM | #3 |
thanks... but that's only overall dims and does not answer the original question. I need physical dimensions on the chassis itself, since I plan on using a totally different transmisson and motor set-up. Chris |
08-19-2010, 06:25 AM | #4 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Seeing as no one in the US will do it for you. Here you go. 2 1/8" outside to outside 1 13/16" inside to inside 2 5/8" skid to rear plate Look at that I even managed to do it in inches. |
08-19-2010, 09:04 AM | #5 |
Newbie Join Date: Aug 2010 Location: Concord, CA
I would have helped, but I just got everything out of the box last night. It's all laid out and calling my name.
08-19-2010, 06:18 PM | #6 |
You best get building then Kirk. and finding a design for you custom skins.
08-19-2010, 09:15 PM | #7 | |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
isn't this pretty much the same dims as an axial skid? it also sounds like an R2 tranny would be a tight squeeze in there.... | |
08-20-2010, 11:55 AM | #8 |
Highlucks thanks for the dims and even imperial (english) metric works fine too... since for the last 2month at work we have a job in house with metric... lol Looking to shoe horn in or squeeze in a Creeper Tranny and motor. Possible Creeper Rock racer Chris |
08-21-2010, 04:46 AM | #9 |
I reckon that may be too much of a squeeze. If you really want to run a different tranny I think an axial might fit best.
