11-28-2011, 11:51 PM | #1 |
Newbie Join Date: Aug 2010 Location: sun valley
| g-made r1 vs axial 10 at crawling
i seen the gmade r1 and thinking of getting one but would like to now how does it do on crawling is it like the ax10 or better i love the look of the r1
11-29-2011, 01:21 PM | #2 | |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
With some tweaking like i did you can make I think very capable in your chosen route though. | |
11-29-2011, 03:14 PM | #3 |
Pebble Pounder Join Date: Feb 2011 Location: kelowna Canada
i own both of them i still perferr the r1 the ax10 does artiqulate more but isnt as stable i find and the r1 just looks cooler |
11-29-2011, 05:46 PM | #4 |
yes i thats what i love the look very nice what do you change to make it a better crawler
11-29-2011, 05:51 PM | #5 |
Tyres!!!!!!!!!!!! change the tires Add wheel weights too. Then maybe the high clearance links that would get it low, heavy and grippy a nice way to start. |
11-29-2011, 09:41 PM | #6 |
how are the shock that it has will hey do good or just go with othere ones im going to get the cage and shocks if is ok and a dig and use my other parts on it let me know what you think on this and the shocks |
11-30-2011, 05:26 AM | #7 |
The shocks are actually very good. If you are crawling set to droop! Also when tightening up, if you just use the supplied plastic spanner they will leak. I use an adjustable spanner to give them an extra half turn or so which has stopped the leaking. Common problem that. |
11-30-2011, 01:20 PM | #8 |
Pebble Pounder Join Date: Apr 2011 Location: Liverpool Y.N.W.A.
When i made my gmade shocks ,i used PTFE tape (plumbing tape) on the threads to get a good seal. They haven't leaked yet (fingers crossed). As Northenerbill says the plastic spanner isn't much 'kop' When i first got mine, i set it up as a rock racer.I went out with some of the lads on a scale run. There were scx10's, hbo rockfighter, cr-01's and a dingo. The R-1 did everthing they could and a lot more... It may of been a bit unfair but it outclassed them all.... |
11-30-2011, 07:12 PM | #9 |
thanks guys i will order one soon if i cant fine a used one i like the way the shocks look any othere things i needto know
12-01-2011, 02:51 AM | #10 |
Have some 3mm washers available. These are needed to stop the top of the shock from sliding off the ball when fitted to the car. It's not a pop on fit, it's a slide on fit onto the ball
12-01-2011, 10:25 PM | #11 |
thanks northernerbill for all the info
12-05-2011, 06:31 AM | #12 |
12-05-2011, 10:40 PM | #13 |
very cool how does it hold up with the xr10 my brother has one
12-06-2011, 01:06 AM | #14 |
It surprised everyone including me, the video does not show how vertical and wet and muddy that climb was. We tried that hill as a laugh expecting no one to make it. The xr10 went first and made it just, I followed and did it at the same pace wow! His xr10 is new and totally totally stock so once he's weighted it and played around with it a bit it will blow the R1 away but it's a nice bench mark to aim for. |
12-06-2011, 09:10 PM | #15 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
Combine them together and they work really well. It is a great basher rig and crawls way beyond what I expected when I built it.Southern Buggy on the Cheap |
