06-17-2012, 04:11 PM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: Massachusetts
| Silly question
So i ordered the 7* steering knuckles for my front axle. In the package was also a set of new links. They are slightly longer than the stock ones and just wanted to know where they go. I assume they replace the stock upper links (i'm running bent lower links). Thanks for any help folks! -bryan |
06-18-2012, 12:15 AM | #2 | |
Newbie Join Date: Apr 2012 Location: Phoenix
| Re: Silly question Quote:
I think the idea is that if you had a stock setup with neutral caster, you add the new longer top links to reduce your pinion angle. This creates a poor caster angle that is corrected by the 7 degree hubs. | |
06-19-2012, 08:51 PM | #3 |
| Re: Silly question
yeah, i threw on the extra upper links supplied w/ the steering blocks, and all it did was clock it forward too much, so went back to the stock upper links and tried the middle and it seemed to work. still going through the testing phase now, hopefully its ready for some crawling come this weekend. -bryan |
Silly question - Similar Threads | ||||
Really silly Li-po question... | Planespotter | Electronics | 20 | 08-21-2010 10:02 AM |
Silly Question... | losimini | Losi Mini-Rock Crawler | 1 | 11-22-2009 01:10 AM |
maybe a silly question? | Rocksolo | Electronics | 3 | 05-20-2009 05:10 PM |
Silly Question | Jake | Tires and Wheels | 1 | 03-21-2009 12:12 PM |
Silly question | flash_gordon | Newbie General | 4 | 11-10-2005 02:25 PM |
