03-27-2013, 09:56 PM | #1 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
| Adjustable Lower/Upper Link Mounts q...
hi guys! i have a couple of questions regarding the hop up adjustable link mounts from JunFac... 1. can the lower adjustable link mounts be installed upside-down? i was thinking to offset the negative angle of the front axle by installing the mount upside-down so i can put the lower links on the longer mounts (originally for the shock) and wouldn't have to lengthen the lower links or purchase the 7* hub carrier. 2. with just the upper link mounts, can the farthest position rotate the axle enough to negate it's negative angle/nose down position? (again, so i wouldn't have to purchse the 7* hub carrier) i am asking so that i would know if i should get these mounts, or the 7* hub carriers instead. |
03-27-2013, 11:03 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Brisbane, Australia
| Re: Adjustable Lower/Upper Link Mounts q...
1. Yes, there is nothing stopping you from installing them in the up or down position. 2. I would get both the 7 degree carriers and the upper adjustable mount. That way you can tune the angle of the diff very precisely to eliminate unwanted steering angle/castor. Have a look in mine and bikerzee24's build threads for plenty of pics. |
03-29-2013, 09:12 AM | #3 |
Rock Stacker Join Date: Feb 2013 Location: North Texas
if you want a visual you can check the thread G-Made WRAITH by v84x4, he has the upper and lower adj. links and his lowers are upside down. he gave me the idea to do the same with mine to get my portal axles clocked right on my wraith. still may get the 7* c-hubs though, dont know yet, waiting on lower adj link mount to come in the mail
04-04-2013, 02:35 AM | #4 |
Thanks for the heads up. Seen it and liking it!
Adjustable Lower/Upper Link Mounts q... - Similar Threads | ||||
Adjustable Upper Link Mount? | HannibalLecter | Newbie General | 4 | 06-16-2006 09:36 PM |
