Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Poor Man's HD locker
Old 05-17-2014, 09:08 PM   #1
Default Poor Man's HD locker
So in an attempt to reduce slop in the drivetrain, I took apart my portals and was going to implement supermoturd's tinfoil fix to fill in the gaps on the outer portal gears and I noticed that there was an opportunity to mod the center ring gear/hub to lock into the axles.
Tools needed,
Tools to disassemble the axle to get to the center gears
3/32 drill bit
Hand drill or drill press
center punch
3mm tap
3mm grub screws
So here goes the steps;
Took out the ring gear;
The idea here was to drill and tap a hole perpendicular to the flat portion of the "D". I had a few 3mm grub screws lying around which was perfect for the job.
So I measured in 3mm from the edge and made my mark with a prick punch, making sure it was exactly center with the "D". You can just see the line on the hub in the photo
From there, I put the gear into a vise and prepped it up for drill and tap. I used a 3/32 drill and a 3mm tap.
Here is one side done, now on to the next, basically repeating the steps above.
Once both ends are tapped, put in your 3mm grubs and it should look like this note that my gear the "D" were not in line so that's why you only see one in the picture.
Here it is in the axle;
Before you tighten these grubs screws, make sure the axle is assembled with the C hub or axle adaptor installed. This will ensure you have proper axle engagement with the portal gears and outer bearings. Once it's all in, tighten the grub screws with locktite (do not over tighten as the metal is pretty soft and you don't want to strip it.
let the locktite do its job here) and reinstall the cover... and you're good to go.
cytogen is offline   Reply With Quote
Old 05-20-2014, 09:26 PM   #2
So what did this do for you may I ask
joneail is offline   Reply With Quote
Old 05-20-2014, 10:36 PM   #3
Default Re: Poor Man's HD locker
It locks the output shaft to the center hub. This remove any slop/play between the two. It's the same idea as the VP locker for the axial axles.
https://www.youtube.com/watch?v=CGWIzHNlDuk
Old 05-22-2014, 09:32 PM   #4
Ok I'm down for this mod
Old 07-13-2015, 02:44 PM   #5
Love the idea. I just might try this. A thought... would it not be smarter to drill on the opposite side? So it pushes the flat part of the axle towards the flat part of the ring gear? just a thought. I will look up how this is on my Axial.
MaFoDes is offline   Reply With Quote
Old 08-01-2015, 08:26 PM   #6
the assumption is that the hole is centered but the bevel might be cut a bit too deep
in either the shaft or the hub
by pushing the shaft onto the bevel it might end up just a bit off center and maybe
incur bearing wear.
same as with the bevels on motors and pinions
cabron is offline   Reply With Quote
Old 08-11-2015, 01:30 AM   #7
Figure this was the best way as other brand do this as well as. Plus, this is the same way you mount a pinion to a motor shaft.
Old 08-13-2015, 06:07 AM   #8
Since the ring gear is already technically on a spool I'm not sure how this is a "locker."
GTSLOW is offline   Reply With Quote
Old 08-13-2015, 09:39 AM   #9
The tolerances between the spool and axles aren't great so there is slop. This locks things to together to reduce slop in the drive train.
Same idea as this,
Axial Wraith Locker for SCX10 and AX10 Type Axles - Vanquish Products
Old 08-13-2015, 04:36 PM   #10
I love this idea, would it be any better to drill all the way through the gear and shaft and use one of the traxxas set screw pins like used for drive yolks?
Sent from my SCH-S738C using Tapatalk
envious8420 is offline   Reply With Quote
Old 08-13-2015, 06:15 PM   #11
I would imagine if you were very exact with the drilling and sizing between the hole and pin, it could work. Other wise there would may be no improvement.
Old 08-14-2015, 06:43 AM   #12
I was thinking more to spread the load to the shaft and lock it to the ring gear shaft input. I have a drill press and access to a bridgeport so precision isnt an issue.
Poor Man's HD locker - Similar Threads
Poor Man's DIY Link Extensions supermoturd G-Made Crawlers 7 06-20-2014 01:33 PM
"Poor man's" Powder coating tjb Tools, and Procedures 15 10-03-2013 07:55 AM
One man's junk is another man's treasure v84x4 EnRoute Berg 48 12-29-2011 07:54 PM
Poor Man's Comm Lathe 3DSteve Electronics 12 10-24-2009 08:34 PM
Poor man's metal brake Thorsteenster Tools, and Procedures 11 08-18-2007 08:42 AM
