07-20-2015, 01:20 PM | #1 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
| R1 lifts right wheel.
Unfortunately i cannot add an attachment (video). But my R1 - in a hard right turn - lifts its right front wheel. Does this sound familair to anyone? |
07-20-2015, 01:23 PM | #2 |
| Re: R1 lifts right wheel.
torque twist.
07-20-2015, 02:39 PM | #3 |
| Re: R1 lifts right wheel. |
07-23-2015, 03:48 PM | #4 |
Newbie Join Date: Jul 2014 Location: what are you a stalker
stiffer shocks mine does it all the time i added the delrin skid plate and upper axle link mounts but stiffer shocks will also work
07-24-2015, 09:32 PM | #5 |
Rock Crawler Join Date: Aug 2011 Location: SB
| Re: R1 lifts right wheel. Any Good shock suggestions? Brand, and length? they look like 90mm.
07-26-2015, 04:42 PM | #6 |
Well, i had the shocks as adviced in this topic: More Articulation But that gave me loads of Torque twist. So i did place the rear ones back to the original mount. Torque twist (front-right) is reduced significant. I am going to make a batteryplate to place a small Lipo on the front axle. Hope the extra weight there will also help. |
07-26-2015, 07:49 PM | #7 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| Re: R1 lifts right wheel. https://www.facebook.com/10000872038...type=2&theater I'm thinking this may be your video on FB? I'm not familiar with the R1, but this doesn't look like normal torque twist to me. Steering to the right is causing something to bind in my opinion. At slow speed on level ground and it's doing this? By the time you put shocks on it that are stiff enough to counteract this, it'll be useless as a crawler. Or am I missing something and speaking out of turn? |
07-29-2015, 12:28 PM | #8 |
Pebble Pounder Join Date: May 2015 Location: nesbit
omg!! thats a first for me, ive been involved in rcs for years and never have seen torque twist flat on the ground like that, its a ghost man! lol
07-29-2015, 12:43 PM | #9 |
i would set it up full droop, install internal springs up front with 2 hole pistons and 35-45 weight shock oil, then turn your shocks upside down! adding weight up front down low will help as well..
07-30-2015, 10:56 AM | #10 | |
You are right, that is my video . I have been trying some things and noticed that if i mount the rear shocks in their stock position, the "effect" is significant less. So i leave 'm as they are now. I also made a battery plate on the front axle for a small lipo. That also helps bringing/keeping the right front wheel down. I checked for binding. Was my first thought as well. But it turns as, as... (what is the expression for it in English?) free as can be. Quote:
08-12-2015, 09:36 AM | #11 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
Can you rotate the trans 180 degrees? I do it to any scx10 i get and it takes care of it. Sent from my SCH-S738C using Tapatalk |
08-09-2016, 06:50 AM | #12 |
Mount your battery on the front axle I run 5" shocks from pro line
08-13-2016, 08:31 PM | #13 |
What's the verdict? Any binding in the drivetrain? #CamBrady2017 |
08-14-2016, 06:51 AM | #14 |
Nope......I still want longer links, but I can walk this right to 90 degrees, LOVIN IT!!, I almost have too much droop, need a strap to stop the driveshaft from rubbing the skid plate. The battery mount helps Last edited by mikemcE; 08-14-2016 at 11:57 AM. |
R1 lifts right wheel. - Similar Threads | ||||
Old Hi Lifts don't die... | carcrafter | 2.2 Scale Rigs | 46 | 01-20-2008 03:19 PM |
high lifts? | bigblazerboy | General Scale Talk | 1 | 11-04-2007 08:56 AM |
Who lifts? | cheapjeep2 | Chit Chat | 82 | 05-12-2007 11:13 PM |
Motors in Hi-lifts? | braceysdad | Chit Chat | 26 | 01-02-2007 03:54 PM |
Cheap hi lifts? | TLTCrawlin | Chit Chat | 3 | 10-27-2006 07:51 AM |
