Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: How many tooth pinion gear for 45T motor?
Old 08-06-2015, 11:14 AM   #1
Default How many tooth pinion gear for 45T motor?
Question, I know I need a 32p pinion gear. But what tooth count is generally used on a 45 turn motor?
Also, how does one access the classifieds here? I'm hoping to find a used set of beadlocks.
Thanks!
GTSLOW is offline   Reply With Quote
Old 08-14-2015, 06:46 AM   #2
Default Re: How many tooth pinion gear for 45T motor?
All depends on how fast you want to go. Id think 12-14 teeth. I use a 10 tooth with a 55t on 3s
Sent from my SCH-S738C using Tapatalk
envious8420 is offline   Reply With Quote
Old 10-04-2015, 10:27 AM   #3
Spur gear size + pinion gives a gear ratio from the motor. More speed = larger pinion and/or smaller spur gear
More torque = smaller pinion and/or larger spur gear
There is no set size per motor really. If your motor is running hot then you will probably want to go towards the more torque set up.
I am running a 12/58 combo with a 55t motor. Speed is ok and torque is awesome.
Scotski is offline   Reply With Quote
How many tooth pinion gear for 45T motor? - Similar Threads
what tooth pinion to start with a 10.5 motor hillbilly76 Vaterra Twin Hammers 3 05-28-2015 08:34 AM
I just found a 9 tooth brass pinion gear that fits! [UPDATED] matts175 Losi Micro-Rock Crawler 14 03-15-2014 07:03 AM
Bully pinion gear - what tooth and pitch? Tomy RC4WD Bully 1 04-18-2009 10:17 AM
