10-15-2015, 07:51 AM | #1 |
Quarry Creeper Join Date: Oct 2015 Location: Wisconsin
| Debating a Sawback
I am debating getting a sawback just due to the price point, what is the honest feedback on durability of everything? how often do you snap a leaf, do the axles hold up, what kind of other hardware will swap over? the motor I have is a brushless reedy so id want to put a 2 spd in it to gear it down? let me know if this is worth my time or if I should go a different route.
10-15-2015, 04:11 PM | #2 |
Rock Stacker Join Date: Sep 2015 Location: Katy
| Re: Debating a Sawback
I have been looking and thinking of getting one as well. Every vehicle has it's pros and cons, plus those differ depending on who is talking. From what I have seen, the Sawback is a decent truck in it's stock form. I'm not so sure how well your Reedy brushless setup would work on any crawler. That's a lot of rpms for a trail roller. You can get an Axial stock 27-55t motor and esc for about $60. If cost is a factor, just dial your throttle gain all the way down and see how it goes. The Sawback seemed as durable as an SCX10 from the videos I have watched. If you do get one, let us know your opinion. If I get one, I will for sure post pics etc. of my horrible building and painting skills lol! I drive them hard and if it holds up, that is what I go by. A shelf queen isn't a crawler. It's a model. =D
10-15-2015, 04:44 PM | #3 | |
| Re: Debating a Sawback Quote:
10-15-2015, 08:07 PM | #4 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
I'm a self proclaimed expert in this matter, so set back and be educated If you end up buying a Sawback, replace the drive shafts when you build it. Stock ones are junk! The skid plate tends to hang to low and gets hung up easily, and the steering isn't horrible, but it aint great either. All is fixable with a little work. The Sawback can be made into one hell of a competitive scaler while retaining the leaf springs. It's very durable once the drive shafts are replaced. I installed Junfac drive shafts and front axle shafts when I built mine and with 20+ hours of run time Nothing has broken. I did replace the springs once. This was after 4 hours of full throttle running through a very bad course at a timed event. I think the biggest drawback is the aftermarket parts. You have to do/make your own modifications. You can't just buy stuff and bolt it on like you would with a SCX10. RPP, Junfac.com and ebay are full of replacement and some upgrade parts. This thing is a scaler not a basher. With gobs of power the front cv's will give up. I run a 35T can motor on 2s. The power is good for very technical crawling and for comps. The steering can be greatly improved with a little grinding of the knuckles and there is a aftermarket skid that will smooth out the bottom of the chassis or you can very easily make your own. Durability of the springs all depends on how you build them. You can pick up used low hour Sawback cheap cause people buy them, run them once and hate them because they don't understand how to set up a leafer and they go back to what they know. With a well setup leafer you will learn that flex is over rated and that lack of flex will actually get you through places that a 4 link suspension might not. The local club (all scx10's) are in amazement at what this little leafer can do. Specially when it walks right through places that their beloved Axial rig can't. |
10-16-2015, 11:43 AM | #5 | |
10-16-2015, 06:33 PM | #6 |
Facebook crawler pages is where I see them for sale in my area. RC4WD leafs will work and will break. Gmade's are actually better and are 20 bucks for a full set. My axles, tranny gears and diffs are all original except for the R1 gears I put in the front, and they are seem to be holding up just fine. The transmission has sounded like its full of gravel since day one, and I've pulled it apart 3 times and everything looks great. Noisy tranny is the trademark of the Sawback I guess. Here's a video of the local clubs main crawl spot. Not much footage of my Sawback, but at the end there is a spot that only one other made it through and it's a Wraith. Once again I run a Holmes BRXL, 35T rc4wd throw away motor on 2s. I don't believe in crazy power in a crawler. https://www.youtube.com/watch?v=8qZyXE0LWV4 |
10-16-2015, 08:13 PM | #7 | |
Newbie Join Date: Jul 2015 Location: Sprignfield
There are some on eBay right now. one, the guy has a home made body that I really want. Kevin | |
11-06-2015, 03:44 PM | #8 |
Quarry Creeper Join Date: Oct 2014 Location: Milpitas
I saw a video of one running and when trying to climb one hill it did this pogo stick bouncy bounce thing on the back wheels and although maybe technically a scale traight it looks silly and I couldn't get around that lol. Now I've built the others it is next on my list.
11-08-2015, 03:54 PM | #9 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
| Re: Debating a Sawback |
01-23-2016, 11:33 AM | #10 |
Pebble Pounder Join Date: Jan 2014 Location: SE Iowa
Absolutely love my Sawback, I do prefer it over my Honcho.
Debating a Sawback - Similar Threads | ||||
Sawback vs. Sawback Sports | scaled | G-Made Sawback | 6 | 04-01-2015 09:04 PM |
Debating between 2S and 3S | 1967Typhoon | Axial SCX-10 | 21 | 07-13-2014 01:46 AM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
Debating | andy27012 | Newbie General | 4 | 01-26-2010 07:05 PM |
Debating doing something gay....... | BEELZEBOB | Chit Chat | 97 | 09-11-2009 10:58 AM |
