Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Gmade XD shocks Aeration screw function
Old 11-15-2015, 10:26 PM   #1
Default Gmade XD shocks Aeration screw function
I just read a ton of posts on the gmade XD shock after assembling them yesterday.
The manual said nothing about the aeration screw and I can find any info here either.
Why is this screw included and how do I make use of this feature?
I was very careful to have no air in the shock when I built them. Why would I want to aerate?
Thanks for help with my newb question
Sethmetal is offline   Reply With Quote
Old 11-16-2015, 05:53 PM   #2
Default Re: Gmade XD shocks Aeration screw function
Nobody loves me.
Old 11-16-2015, 05:57 PM   #3
If I had the answers I would give it to you lol
Emedina1222 is offline   Reply With Quote
Old 11-16-2015, 06:20 PM   #4
MODERATOR™
EeePee's Avatar
Hey are you guys using iPhones and iPads and Tapatalk?
If you loosen the screw does oil come out?
EeePee is offline   Reply With Quote
Old 11-16-2015, 07:46 PM   #5
try this link https://www.youtube.com/watch?v=G45HrTcG4i4
AngelowDoom is offline   Reply With Quote
Old 11-17-2015, 12:06 AM   #6
Thanks Angelow, but alas no discussion of the screws function.
This video is more what I imagined it to be used for. I guess I'll go with it:
http://youtu.be/ZW8LqHldI7w
Old 11-17-2015, 06:39 PM   #7
The screw is to let oil out
Old 11-17-2015, 09:52 PM   #8
When would I let air in?
Old 11-18-2015, 12:53 AM   #9
MODERATOR™
EeePee's Avatar
It's to let oil out. Just like step 10 in that video.
Old 11-23-2015, 11:10 AM   #10
Natedog's Avatar
Never, it's already in there by the nature of non-bladder (aeration) shock setup.
Old 11-24-2015, 07:37 AM   #11
I guess the term aeration made me think that I would aerate the shock. Which to me sounds like "add air", but I'm no English Major.
You would think they'd call it the oil purge screws if it was to release oil.
Anyway, I think you can use this screw to relieve pressure after assembly. If you want a low pressure shock. I actually want a fast rebound for my needs.
I just add the proper amount of fluid normally, but I guess that screw is an option if I ever make a low pressure setup. But that seems like a major waste with these piggybacks. I don't even think it would really activate the spring in the reservoir in a low pressure setting.
Old 11-26-2015, 07:10 PM   #12
So, here's how I've decided to set my gmade shocks.
I fill them as described with reservoir filled first then compressed fully. I used the included oil with two hole piston.
When putting together, I did not depress the shaft. Providing a high pressure setup.
I believe that when the shock hydro locks that's when it will have enough force to engage the spring in the reservoir.
I used the screw on the piggyback so that the spring engages at 5/6 compression. This essentially gives me a progressive bumpstops after the hydraulics of the shock have done their job.
I believe this is the way it was intended, but the directions don't describe it this way.
Been happy with it so far.
Gmade XD shocks Aeration screw function - Similar Threads
Gmade 85 XD Aeration Screw Sethmetal Newbie General 3 11-16-2015 08:10 AM
TH with Gmade Aeration shocks (GCM KIT) Syncrog60 Vaterra Twin Hammers 9 01-28-2015 12:20 AM
Shocks? TLR 22SCT vs Gmade Aeration? STANG KILLA SS U4RC 11 12-18-2014 11:26 PM
