Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: R1 lifts right wheel.
Old 07-20-2015, 01:20 PM   #1
Default R1 lifts right wheel.
Unfortunately i cannot add an attachment (video). But my R1 - in a hard right turn - lifts its right front wheel.
Does this sound familair to anyone?
MaFoDes is offline   Reply With Quote
Old 07-20-2015, 01:23 PM   #2
Scale Detail Engineering
Default Re: R1 lifts right wheel.
torque twist.
johnnyh66 is offline   Reply With Quote
Old 07-20-2015, 02:39 PM   #3
Originally Posted by johnnyh66 View Post
torque twist.
Thought so already. Any suggestions how to solve it? It looks kinda silly....
Old 07-23-2015, 03:48 PM   #4
gr1
stiffer shocks mine does it all the time i added the delrin skid plate and upper axle link mounts but stiffer shocks will also work
gr1 is offline   Reply With Quote
Old 07-24-2015, 09:32 PM   #5
Any Good shock suggestions? Brand, and length? they look like 90mm.
desertdude is offline   Reply With Quote
Old 07-26-2015, 04:42 PM   #6
Well, i had the shocks as adviced in this topic:
More Articulation
But that gave me loads of Torque twist.
So i did place the rear ones back to the original mount. Torque twist (front-right) is reduced significant. I am going to make a batteryplate to place a small Lipo on the front axle. Hope the extra weight there will also help.
Old 07-26-2015, 07:49 PM   #7
https://www.facebook.com/10000872038...type=2&theater
I'm thinking this may be your video on FB? I'm not familiar with the R1, but this doesn't look like normal torque twist to me. Steering to the right is causing something to bind in my opinion. At slow speed on level ground and it's doing this? By the time you put shocks on it that are stiff enough to counteract this, it'll be useless as a crawler. Or am I missing something and speaking out of turn?
Jeepiac is offline   Reply With Quote
Old 07-29-2015, 12:28 PM   #8
omg!! thats a first for me, ive been involved in rcs for years and never have seen torque twist flat on the ground like that, its a ghost man! lol
firstpasstommy is offline   Reply With Quote
Old 07-29-2015, 12:43 PM   #9
i would set it up full droop, install internal springs up front with 2 hole pistons and 35-45 weight shock oil, then turn your shocks upside down! adding weight up front down low will help as well..
Old 07-30-2015, 10:56 AM   #10
You are right, that is my video .
I have been trying some things and noticed that if i mount the rear shocks in their stock position, the "effect" is significant less. So i leave 'm as they are now. I also made a battery plate on the front axle for a small lipo. That also helps bringing/keeping the right front wheel down.
I checked for binding. Was my first thought as well. But it turns as, as... (what is the expression for it in English?) free as can be.
Old 08-12-2015, 09:36 AM   #11
Can you rotate the trans 180 degrees? I do it to any scx10 i get and it takes care of it.
Sent from my SCH-S738C using Tapatalk
envious8420 is offline   Reply With Quote
Old 08-09-2016, 06:50 AM   #12
Mount your battery on the front axle I run 5" shocks from pro line
mikemcE is offline   Reply With Quote
Old 08-13-2016, 08:31 PM   #13
What's the verdict? Any binding in the drivetrain?
#CamBrady2017
Brake Weight is offline   Reply With Quote
Old 08-14-2016, 06:51 AM   #14
Nope......I still want longer links, but I can walk this right to 90 degrees, LOVIN IT!!, I almost have too much droop, need a strap to stop the driveshaft from rubbing the skid plate.
The battery mount helps
R1 lifts right wheel. - Similar Threads
Old Hi Lifts don't die... carcrafter 2.2 Scale Rigs 46 01-20-2008 03:19 PM
high lifts? bigblazerboy General Scale Talk 1 11-04-2007 08:56 AM
Who lifts? cheapjeep2 Chit Chat 82 05-12-2007 11:13 PM
Motors in Hi-lifts? braceysdad Chit Chat 26 01-02-2007 03:54 PM
Cheap hi lifts? TLTCrawlin Chit Chat 3 10-27-2006 07:51 AM
