Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Sawback and Komodo
Old 01-10-2016, 12:31 AM   #1
Default Sawback and Komodo
Hello all. I just purchased a Gmade Komodo and I'm stoked. One question I have is will the Sawback parts fit the Komodo? I know they share the same axles and frame but what about everything else?
Thanks for your time.
Jcoff541 is offline   Reply With Quote
Old 01-11-2016, 06:33 PM   #2
Default Re: Sawback and Komodo
A lot of the parts if not all will work with the Komodo. When you receive your kit there will be a sheet of aftermarket parts for the Komodo. Searching the part number usually comes up as a saw back hop up part.
Randy Williams is offline   Reply With Quote
Old 01-12-2016, 12:19 AM   #3
The Sawback sliders will also fit.
TrailDawg362 is offline   Reply With Quote
Old 01-18-2016, 01:20 PM   #4
quite a few parts cross over, I have some fitted to mine Komodo
JamminJP is offline   Reply With Quote
Old 02-05-2016, 11:28 PM   #5
Can you install leaf springs on the Komodo since it has a 4 link suspension? If so, do you install both the shocks and the leaf springs or just one or the other?
Old 02-06-2016, 06:52 AM   #6
I think you would need to lose the four link to use leaf springs, but if you do that you should have just got a sawback, they are fifty bucks cheaper and come with the leafs already. And if you go with leafs you want your shocks just for damping, that means no springs installed on the shocks.
dubyas1989 is offline   Reply With Quote
Old 03-31-2016, 12:23 PM   #7
Correct, you would have to remove the 4 link and the springs from the shocks in order to run leaf suspension.
As for "why do it?", I personally would like to leave the coils up front and convert the rear to leaf. This would be a much more life like set up as pretty much all pickups run coil/leaf combos.
Dragonii is offline   Reply With Quote
Old 03-31-2016, 07:09 PM   #8
I went to GMADE's website - I wanted to buy a Komodo so I clicked on the only dealer listed in the US and their website link did not work
How can I buy one?
Thanks
Axial Rose is offline   Reply With Quote
Old 03-31-2016, 08:01 PM   #9
Pretty sure it would be way cheaper to get a sawback and convert the front to links, then vice versa.
Old 04-01-2016, 10:05 PM   #10
How can I buy one?
Thanks
Gmade Komodo 1/10TH SCALE CRAWLER KIT
Jeepiac is offline   Reply With Quote
Old 04-01-2016, 10:10 PM   #11
Word of warning. Even though I see most online hobby stores listing axles as Sawback/Komodo, there is a difference. Komodo and the Sawback 4LS use 5mm longer axles than the Sawback. They will interchange, but you'll need to use 10 mm hubs with the Komodo/Sawback 4LS axles when putting them in a Sawback.
Old 04-02-2016, 11:04 AM   #12
i noticed the same difference just for the rear axles.wonder why they didn't use wider hubs on the rear only for extra width?
thead is offline   Reply With Quote
Sawback and Komodo - Similar Threads
Sawback vs. Sawback Sports scaled G-Made Sawback 6 04-01-2015 09:04 PM
Wild Willy On A Sawback [Sawback Solo Run] ifulg G-Made Sawback 1 12-24-2013 08:06 PM
komodo 2.2 bamaboy1992 General Crawlers 6 09-20-2011 10:03 PM
