11-04-2016, 08:58 AM | #1 |
Newbie Join Date: Oct 2016 Location: West Central IL.
| R1 RTR not happy
Got the R1 RTR nothing is waterproof- 1 shock don't go all the way down-Pinion gear set screw stripped never even got to use it yet!!!! It's not good when you have to fix it before U use it. Should have bought the kit would have been cheaper in long run. Crawl On
11-04-2016, 10:11 AM | #2 | |
| Re: R1 RTR not happy Quote:
Nope....... The stock pinion is too soft, no big deal . You paid $100.00 for TX/rx, dig, esc, and two motors. The motors and Tx are worth that easy. I upgraded with BR minis as I blew up my stock esc, destroying it, due to me.The dig finally gave up last week. You can waterproof if you must. The rig overall is a joy to run. Hang up and Drive | |
11-04-2016, 10:57 AM | #3 |
I built mine with Axial parts so it's 'technically' not an R1 since it doesn't have portal axles. Solid as a rock, though. Let me whore it... Sucks to have a broken RTR. A sack o Robinson pinioned isn't too much. Shocks are usually the first upgrade of many. Good luck and keep us posted. |
11-04-2016, 01:56 PM | #4 |
Got new pinion gear so now it runs, I have a ? about rear steer can I use another channel on the receiver or what does it take to power it what is a good waterproof servo and horn to get for it any info would help. Thanks Crawl On
11-04-2016, 03:00 PM | #5 |
The rear steer should be covered in the manual. But the 3rd channel on the Rx should be the one to use.
11-06-2016, 10:11 PM | #6 | |
Pebble Pounder Join Date: Sep 2013 Location: Santa Cruz
The RTR transmitter is only a two channel system so you'll need to use one of the heyOK or wiggle systems. MikeMCE mentioned the name in that linked thread. I had a really detailed reply written up for you, but it got lost when trying to submit it. Sorry about that. Bottomline, 4ws is a blast to have, transforms the turning capabilities of the R1, but it takes some work to set it up. | |
R1 RTR not happy - Similar Threads | ||||
Twin Hammers Happy but not so happy at the same time | angeloreyes27 | Vaterra Twin Hammers | 0 | 08-20-2013 06:23 AM |
