12-05-2017, 12:50 AM | #1 |
Newbie Join Date: Jan 2014 Location: Kotka, Finland
| Bishop's RC Gmade GOM ULTRA4-truck
Hello! Here is my entry for build scale looking Ultra4/KOH -Truck. I also like way GOM looks, and everyone has seen wraiths, yetis and Bombers... I pick my Gmade GOM-kit on EuroRC I decided to go with brushed setup and 550 size 15t FTX-motor. And few upgrades for the start. So far build is went with no problems. Let the pics tell rest. I'm using Transmiter Mod Flysky GT3c 6ch and hi-lo-dig-setup Testing gearbox and dig video |
12-05-2017, 05:01 AM | #2 |
| Re: Bishop's RC Gmade GOM ULTRA4-truck
Build continues. Had to trim front servo/reciever box bracket for 550 size motor. Without trimming it won't fit. I found @ ebay wooden art mannequins. just replaced wooden head for a helmet. |
12-05-2017, 09:26 AM | #3 |
Nice, another GOM build! Interested to see how your build comes out.
12-12-2017, 04:56 AM | #4 |
Rock Stacker Join Date: Jun 2016 Location: England
Nice to see someone else also go for a silver chassis and cage Sent from my iPhone using Tapatalk |
12-13-2017, 01:21 PM | #5 | |
| Re: Bishop's RC Gmade GOM ULTRA4-truck Quote:
Little bit of progress on build. Now roller and electrics on just for test. Wheel speed is ok, stock 13t pinion and 550 size 13t motor. It still crawls and bash. Also tested gear/dig sifter... working properly. MAX turning radius Stock shocks feels pretty good. Some paint work done. Diamond plate for looks. Too shiny. Also plenty of room on top of battery tray for micro servo steering wheel mod | |
12-28-2017, 12:45 AM | #6 |
GOM Build is almost ready, just few scale details remains... Interior and driver figure adjustments. RC4WD Diamond plate on dash board. And Roll cage done. HW 1080 ESC and reciever in its own box under the hood. Plenty of room for bigger battery. (Now running with 3s 2200mAh lipo) Also ESC on/off switch there. Here pics when build is done and after first run. I got really big sponsors at the King of Hammers 2018 race. I played the idea of participating in the ULTRA4 KOH-18 event. TRX-4 Spare tire, GOM sway bar at rear, at front inner fender plates for hiding electronics. Brushless esc cooling fans. To do list: Side window nets, seat belts, lights, led bar and fuel tank. Got bad luck, i think that 1 screw bag is missing from kit... Scews that holds roll cage/tube together 2,5mm x 12mm screws. I replace them with body panel screws, they are 4mm shorter.... they aren't going to hold roll cage together long. Also broke the roll gace at the first run... just light bashing on rocks and outside temp was about +1c° GOM crawling performance is really good. And my motor choise was 10/10. FTX 550 size 15t brushed motor (only 15€) with stock gearing. Enough wheel speed on grip surfaces, and still crawls smoothly. I like this rig a lot, it crawls well, can bash and rock bounce with it But GOM's durability considers me Video @ first is coming soon! |
12-28-2017, 11:26 PM | #7 |
| Re: Bishop's RC Gmade GOM ULTRA4-truck |
12-29-2017, 02:44 PM | #8 |
Quarry Creeper Join Date: Sep 2017 Location: UK
My sons GOM broke the cage in exactly the same place on his first run out, again cold temps and one roll. Maybe there is an issue with the plastic on the cages..... Any tips on a glue to bond it at all ? |
12-30-2017, 03:32 AM | #9 |
Pebble Pounder Join Date: Jul 2013 Location: Manchester,UK.
[QUOTE=Pisepise;5780869]Video on first test. Great video sir Some great action shots and love the trailer. |
12-30-2017, 08:02 AM | #10 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
Excellent video! |
01-02-2018, 03:25 PM | #11 |
Sounds kinda hokey, and certainly not scale, but I've successfully sleeved the broken sections of my twin hammers cage with plastic rod found at the local hardware store and some E6000 adhesive. Thanks for posting good pics of the guts of this new rig. Still not sure what to think of the shifting mechanism. |
01-05-2018, 05:56 PM | #12 | |
01-06-2018, 12:50 PM | #13 | |||
[QUOTE=tachikoma1373;5781295] Quote: Thanks! Quote:
02-24-2018, 08:29 AM | #14 |
Rock Stacker Join Date: Feb 2018 Location: Ozarks
Loving the custom paint on the chassis, I will be painting mine as well. Sounds like I should have a spare roll cage on hand too.
03-09-2018, 05:32 PM | #15 | |
Basically to get your mesh set you can either spin the motor and adjustment plate clockwise or counterclockwise...... but if you try to do it clockwise it will hang lower than the plastic piece below it. 550's are usually no thicker than a 540's so length should be the only issue. Well on the bright side the motor should stay nice and cool Not meant to be a dig on your build, I just didn't want anyone else to needlessly do the same like I almost did BTW I like the way your Bomber turned out, uh I mean Gom Last edited by HumboldtEF; 03-09-2018 at 05:36 PM. | |
04-05-2018, 01:30 PM | #16 |
04-05-2018, 02:01 PM | #17 |
That's a good looking GOM. I love what you did with the fans. Genius! |
04-06-2018, 01:18 PM | #18 |
06-13-2018, 11:33 PM | #19 |
Little update here: Stock dog bone driveshaft got broken. CVD's for replace, @ first test i got cvd pin broken So now looking for moore durable solution... Added alloy wheels. Stock foams are way too soft. Need harder ones. Here some speed run videos, first on early spring on ice snow trail https://www.youtube.com/watch?v=Etzp52iviX0 And my latest GOM video Ultra4 ROCK BOUNCING Always wanted to do good realistic rock bouncing video, it was fun to climb with speed rocky hills... SUPER FUN |
Bishop's RC Gmade GOM ULTRA4-truck - Similar Threads | ||||
Soze's GMADE GOM GR01 Build | soze | G-Made Crawlers | 69 | 08-20-2021 12:45 AM |
Coming soon .....GMADE GOM-GR1 Rock Buggy | big1717 | G-Made Crawlers | 951 | 05-12-2019 02:43 PM |
In Stock - Gmade USA GR01 GOM Upgrade Parts! | RPP Hobby | RPP Hobby | 0 | 11-09-2017 10:46 AM |
Gmade Gom crawling on the backyard course | HumboldtEF | Videos! | 2 | 11-03-2017 09:39 AM |
New Gmade USA GOM Rock Buggy Kit - In Stock! | RPP Hobby | RPP Hobby | 0 | 10-05-2017 10:30 AM |
