06-21-2018, 03:57 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: Plymouth
| GOM slipper question
So i took a guess when building on how tight to make it.. I made it too tight and blew my stock drive shafts out when i got stuck between some rocks. So i upgraded to the Junfac steel ones. but my question is, after being built it looks pretty difficult to get back in there without tearing the thing down. whats the shortest route to get this done ? unbolt the whole transmission ? any tips would be appreciated, thanks!
06-21-2018, 04:15 PM | #2 |
Quarry Creeper Join Date: Jun 2017 Location: St George
| Re: GOM slipper question
I just installed a mip yeti driveline and it takes some patience. I used one of the allens that come in the tool kit and you can only turn it a 1/4 turn at a time. It still quicker then taking off the panels and interior Sent from my iPhone using Tapatalk |
06-21-2018, 05:01 PM | #3 | |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: GOM slipper question Quote:
Is this the front or rear ? Sent from my iPhone using Tapatalk | |
06-21-2018, 05:02 PM | #4 |
It’s about the same front or rear Sent from my iPhone using Tapatalk |
06-21-2018, 05:16 PM | #5 | |
The front is easy just drill a hole in the interior , drivers footwell back corner ( heel area) The rear is a little bit more tricky , a hole needs to be marked out from the edges , Start with a smaller drill than the finished size to give yourself a bit of leeway if your measurements aren’t quite perfect and adjust the whole as required Sent from my iPhone using Tapatalk | |
06-21-2018, 09:25 PM | #6 | |
I’m asking about the slipper clutch. Sorry for the misunderstanding. The clutch is too tight. And it looks very difficult to reach. There’s a dust cover over it that I can’t even get the top bolt out of. The shafts are done. That was easy. My question is what’s the easiest way to adjust the slipper Sent from my iPhone using Tapatalk | |
06-22-2018, 02:49 AM | #7 | |
That’s ok I did wonder if it was that you were on about , Yep it is possible just fiddly i have done it myself at the g6 after its maiden voyage , you do need to remove esc and most screws from either side of front end . I always go by the rule : tighten until it’s really tight and then back off 1.5 turns that will be fine Sent from my iPhone using Tapatalk | |
06-25-2018, 06:06 PM | #8 | |
Thanks for the tip. I always wondered how tight to make them. With my slash and what not it’s easy to reach so I just drive it and mess around till i get it right. Not so easy on the GOM. But man it’s a fantastic rig. Sent from my iPhone using Tapatalk | |
06-26-2018, 02:49 AM | #9 |
Your very welcome buddy , yeah it’s got some really cool features and is very capable indeed Sent from my iPhone using Tapatalk |
GOM slipper question - Similar Threads | ||||
Slipper clutch question | Awesome Kong84 | Mega/Monster Trucks | 2 | 11-08-2017 02:34 PM |
Slipper Question | Gimpdiggity | Vaterra Twin Hammers | 1 | 01-25-2015 09:52 AM |
Slipper Clutch Question? | mmatthews | Losi Mini-Rock Crawler | 5 | 08-03-2011 01:48 AM |
another slipper question | redrokin00XJ | Team Losi Comp Crawler | 5 | 02-27-2011 02:52 PM |
slipper question | spor706 | Team Losi Comp Crawler | 2 | 02-16-2010 08:22 PM |
