01-16-2020, 06:28 AM | #1 |
Newbie Join Date: Dec 2019 Location: Washington Court House
| Spur Gear For G-Made GOM GR01
Need help if possible. Is there a 56T 32P Metal Spur Gear replacement for the plastic one that comes in the Gmade GR01 GOM ROCK BUGGY kit. Would anyone know of one from another manufacturer that would work.
04-04-2022, 05:14 PM | #2 |
Newbie Join Date: Feb 2022 Location: Bucks county
| Re: Spur Gear For G-Made GOM GR01
I have looked all over and no one makes upgrade spur gears for any gmade trucks. I have seen websites sell spur gear sets but they don’t have the same tooth count but not sure if the will fit in the axle. Sent from my iPhone using Tapatalk |
04-04-2022, 06:13 PM | #3 |
I wanna be Dave Join Date: Sep 2011 Location: Douglassville, PA
This should work... use some Axial slipper pads and it should drop right in, no? https://www.amainhobbies.com/robinso...BoChOEQAvD_BwE This one even has the slipper pads. For $20, worth a shot... https://www.amainhobbies.com/xtra-sp...BoCRDwQAvD_BwE |
04-04-2022, 08:48 PM | #4 |
I wanna be Dave Join Date: Jun 2017 Location: Humboldt county
If you do this make sure the pinion is hardened steel or it will get chewed up over time. If you're looking for a metal spur for the purpose of "upgrading" just know that plastic spurs hold up pretty damn well as long as your mesh is setup correct. Metal on metal gears are also louder. I did a full metal spur and pinion on a Wraith 2.2 and it was not worth it, I chewed up a few pinions before I realized I needed a hardened steel pinion. I ended up pulling it out eventually as it did nothing for me but add weight. |
Spur Gear For G-Made GOM GR01 - Similar Threads | ||||
Soze's GMADE GOM GR01 Build | soze | G-Made Crawlers | 69 | 08-20-2021 12:45 AM |
Bomber Or Gom GR01 | chevy4life | General Scale Talk | 5 | 12-19-2018 02:54 PM |
Gmade GR01 GOM - WILLYS BUGGY | IZI-RC | Videos! | 3 | 10-31-2018 08:32 AM |
In Stock - Gmade USA GR01 GOM Upgrade Parts! | RPP Hobby | RPP Hobby | 0 | 11-09-2017 10:46 AM |
