10-25-2016, 05:56 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: ny
| I need help
What's the easiest way to set the transmission gear mesh I put the motor in the Komodo but I don't like what sounds like gears slipping and crunching ...lol Sent from my iPhone using Tapatalk |
10-25-2016, 06:06 PM | #2 |
Rock Stacker Join Date: Jan 2016 Location: goldsboro
| Re: I need help
on these 32p transmissions,i snug down the motor screws with the mesh close,i use a small screwdriver to slowly turn the pinion and find the tightest spot.at that point i have just a small tick of play between the spur and pinion at the tightest place.the loosest place will be a little wider but won't hurt anything and will be much quieter.i also run rr pinion gears because the stock pinions have a lot of run out.be sure to use plenty of grease.hope this helps
10-25-2016, 06:13 PM | #3 |
| Re: I need help
I also have a rr pinion on the 35t rc4wd motor I'm gonna try it the way I always did with the nitro motors Piece of paper ... maybe it will or maybe it won't work Sent from my iPhone using Tapatalk |
10-25-2016, 06:25 PM | #4 |
| Re: I need help
Piece of paper is the way to go, nitro and electric. Gmade transmissions are louder than most. My Sawback is way loud. |
10-25-2016, 06:47 PM | #5 |
| Re: I need help
I haven't had my sawback long enough to know it was loud ... lol Sent from my iPhone using Tapatalk |
10-25-2016, 08:49 PM | #6 |
Quarry Creeper Join Date: Jul 2014 Location: saranac
| Re: I need help
Yeah the gmade trannys sound terrible, haven't busted mine yet with almost a year on it though.
10-25-2016, 08:51 PM | #7 |
| Re: I need help
I've had this in my possession for a few months now and still haven't given it a shake down Sent from my iPhone using Tapatalk |
10-26-2016, 02:21 PM | #8 |
Rock Crawler Join Date: Oct 2013 Location: The Netherlands
| Re: I need help
Mine doesnt sound loud anymore after switching to a rc4wd 32p pinion.
10-26-2016, 08:14 PM | #9 |
| Re: I need help
Will an axial skid and trans work with this truck Sent from my iPhone using Tapatalk |
10-29-2016, 07:36 PM | #10 |
| Re: I need help |
10-30-2016, 06:16 AM | #11 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
| Re: I need help
Yeah, the gmade trans is 32 pitch gears out of the box. It's noisy to some people but I cut my teeth on tamiya kits as a kid so it sounds great to me. |
10-30-2016, 03:20 PM | #12 |
| Re: I need help |
10-31-2016, 06:36 AM | #13 |
| Re: I need help |
10-31-2016, 01:16 PM | #14 |
Newbie Join Date: Apr 2016 Location: Belgium
| Re: I need help
Same here. Never used the stock pinion and the tranny is not noisy at all.
10-31-2016, 06:04 PM | #15 |
| Re: I need help
So should I replace the trans gears? Sent from my iPhone using Tapatalk |
10-31-2016, 09:15 PM | #16 |
| Re: I need help
I just installed a robinson racing pinion and some grease and haven't had a problem so I doubt that you need to replace the trans gears.
10-31-2016, 11:50 PM | #17 |
| Re: I need help
I have a rr pinion ... I'll just put a shit load of grease between them Sent from my iPhone using Tapatalk |
11-01-2016, 01:34 AM | #18 |
| Re: I need help |
11-01-2016, 04:06 AM | #19 |
| Re: I need help
Oh ok ... like I've said I have a Robinson racing pinion Sent from my iPhone using Tapatalk |
