01-15-2017, 12:44 AM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Golf course
| sawback dimensions needed
Long story short I'm in need of some dimensions off a sawback. My sawback is not within reach and I'm in the process of making sliders and bumpers but failed to get all the measurements I need to do so. Thanks in advance! I need the following dimensions: - distance from center of hole to center of hole between the slider mounts on the side of the frame. - outside width of the frame rails ( I believe its around 7.5cm?) |
01-15-2017, 01:13 AM | #2 |
Rock Crawler Join Date: Oct 2013 Location: The Netherlands
| Re: sawback dimensions needed
I will measure it, brb
01-15-2017, 01:17 AM | #3 |
Front width is 76mm
01-15-2017, 01:20 AM | #4 |
Distance between slider mounts (outer holes) are 60mm.
01-15-2017, 01:22 AM | #5 |
I found out the frame width in the rear is 72mm. But maybe that's because of a body mount i made.
01-15-2017, 01:23 AM | #6 |
| Re: sawback dimensions needed |
01-15-2017, 01:28 AM | #7 |
Measured the front frame width again without my bumper mount and it's 75.65mm. So think you where right with 75mm
01-15-2017, 10:10 AM | #8 |
Thanks a ton WesleyRoy!! You da man.
01-15-2017, 10:12 AM | #9 |
What do you mean by outer holes on the slider mounts? I'm looking for the holes on the top of the little slider brackets.
01-15-2017, 12:48 PM | #10 |
I measured the outer holes on the frame rails.
01-15-2017, 12:48 PM | #11 |
I dont have sliders
01-15-2017, 08:46 PM | #12 |
Can anybody else check the slider dimensions? Thanks
01-15-2017, 08:51 PM | #13 |
WesleyRoy, do you have the little tabs that are mounted to the frame rails on the side? Those are the mounts I'm referring to
01-15-2017, 10:34 PM | #14 |
Oke i will measure again. I see what you mean.
01-15-2017, 10:35 PM | #15 |
Is it Oke to measure the holes of the mounting tabs. As i dont have the mounting tabs mounted.
01-15-2017, 11:02 PM | #16 |
Yes that should work.
01-16-2017, 10:48 AM | #17 |
50.00mm
sawback dimensions needed - Similar Threads | ||||
Body Dimensions needed...ASAP...please :) | TURBOFEST | Axial AX10 2nd-gen | 6 | 12-02-2013 10:50 AM |
1.9 rim dimensions needed | _WEAPON_X_ | Tires and Wheels | 0 | 09-28-2012 05:43 PM |
Dimensions of battery tray needed asap | derek_18mt | Venom Creeper | 16 | 10-30-2009 10:00 AM |
Kyosho Blizzard - Dimensions needed | sweli | Non Crawler RC's | 1 | 02-13-2009 10:17 AM |
Dimensions needed to make clod tuber. | DUKEMURMUR | Tamiya Clod Buster | 4 | 02-12-2006 08:47 PM |
