Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Bought a tow rig for the crawlers, dialup=no
Old 05-25-2005, 12:22 PM   #1
slugzracing's Avatar
Default Bought a tow rig for the crawlers, dialup=no
New bright F-150, 16 is inch wheel base and 10 inches wide
Note the size compared to the jeep, this thing is massive!
Hehe
It is going to take some work but I need to make a real chassy for it as well as put a set of clod axles under it and I am thinking about mounting my winch to this thing to take the weight off of the jeep. I also need to fab up a goose neck trailer and hitch but that wont be hard, I might have to make it a dual car hauler :P
Sad thing is it came out of the box damaged so I also have soem body work to do, the hood has a crack and there are some scuffs in the paint so it will be repainted, what color do you think it should be?
slugzracing is offline   Reply With Quote
Old 05-25-2005, 01:36 PM   #2
do you know what goth green is? that would look hard core is flames on a black to gray fade with those rims!!
lodikrawlingkiller is offline   Reply With Quote
Old 05-25-2005, 01:38 PM   #3
like this color
Old 05-25-2005, 01:39 PM   #4
and "rhino liner" the bed
Old 05-25-2005, 04:48 PM   #5
Make it 4x4 !
RampageFSJ is offline   Reply With Quote
Old 05-25-2005, 04:50 PM   #6
Woops, didn`t read the whole post .
Old 05-26-2005, 09:54 AM   #7
not to jack your thread, but....
like this?
for a size reference, that's a 5 foot diameter table.. the wheelbase is correct now, i had to have a piece made to fit. the chassis side rails are a du-bro wing holder (used to be part of the 8x8x8 chassis), esp clodzilla cross braces (the round ones), and a custom made center piece (just 1/8" ally bent to a c shape)
here's the orig clod wheels, and the trailer
i run a 12v lead acid battery, 2 super roosters, stock silver cans and thunder tiger reductions (9t in 9t out for like 400:1 reduction) it will pull over 250 lbs in a shopping cart!
also, ps1 and a 7 inch monitor fit in the bed nicely....
bdr
bigdogrod is online now   Reply With Quote
Old 05-26-2005, 01:27 PM   #8
Bigdog, simmilar. The chassy will be stell box tubing and litearlly look like a 1-1 chassy. I dont want it to sit super high as I am going to be trying for a scale looking truck that can be driven on some rocks. 2.2 masher 2ks fit in the wheel wells perfectly but I will probably be using All Ts or swampers.
Lodikrawling I like that green, I might just do that, a two tone black green hmmm
Old 05-26-2005, 01:56 PM   #9
I saw a picture of a touring car painted up in tribal flames with that green and thought it looked sicc. I'll try to find the picture.
Old 05-26-2005, 02:00 PM   #10
Old 05-27-2005, 05:16 PM   #11
If you want realism, go to a Ford dealership an pick up a brochure with the factory colors and pick from there. got a Jugg body painted in a factory sandstone color and it looks sweet.
flatfender is offline   Reply With Quote
Old 05-27-2005, 05:39 PM   #12
a friend of mine has a 04 f150 with the southern comfort package. its black like that but with a tan/gold fade from the bottom, with 20''s and a billet grill. looks hot, you should do that. I'll see if I can find a pick of it.....
Ur Next is offline   Reply With Quote
