| | #1 |
| Newbie Join Date: Nov 2004
| does any one else have problems with the truck leaning to one side it leans to the one side all the time it torges and never settles even after it reaches top speed ????? |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Aug 2004 Location: woods cross utah
| what kind of truck ? are your shocks built right? |
| | #3 |
| Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
| welcome to torque twist, |
| | #4 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| Search for torque twist and you should be able to find ways to help or fix your problem. Not even seeing your rig,can you get 90 degrees of articulation? If you can,theres part of it. Limit your wheeltravel to about 60 degrees tops. Link mounts,shock mounts and shock set up will be ways to eliminate the torque twist. Right now I'm running 75 weight oil,stock maxx springs on my shocks and I'm happy. It's not all in the shocks though,link placement has a big play in it to. You need to properly set up your links for the best results. |
| Thread Tools | |
| Display Modes | |
