Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: possible trannies?
Old 05-31-2005, 06:26 PM   #1
200th engineering
spookyseven's Avatar
Default possible trannies?
what other trannies can you run other than a e-maxx that will halndle big wheels? i can find savage and lst trannies on ebay but would they work at all for a crawler?
spookyseven is offline   Reply With Quote
Old 05-31-2005, 06:51 PM   #2
There anything better than a custom tranny. Like mine.
ttrmike is offline   Reply With Quote
Old 05-31-2005, 07:06 PM   #3
prolly not. try it and find out. i dont think anyone else has tried it
ILoveRCRockCrawlin is offline   Reply With Quote
Old 05-31-2005, 07:19 PM   #4
nitro trannies would be hard to adapt because some have parts that engage at certin rpms so they would be hard to use.
I really dont know if you could do it, but i heard that the lst tranny is pretty beefy...
Frkan is offline   Reply With Quote
Old 05-31-2005, 07:23 PM   #5
That Was Totally Ninja!
rbgerrish's Avatar
We've run Stampede trannies in many larger scale trucks with good results. Metal Idle gear is a good idea.
rbgerrish is offline   Reply With Quote
Old 05-31-2005, 08:32 PM   #6
just need to adjust the shift points.
3 speed Savage tranny might be cool to run in a crawler
flatfender is offline   Reply With Quote
Old 06-06-2005, 03:07 PM   #7
Yeah you have to get the aluminum idler gear and possibly a Cold Fusion Racing main diff gear ($60). I can pretty much guarantee that the tranny gears will never go with that setup. Also try to get a 12t Robinson Racing pinion since they are made out of harder metal than most pinions. Either Duratrax, HPI, or Kimbrough make carbon fiber spurs gears for it. I personally have never seen a metal spur unless you want to get a custom one. Remember its 48 pitch.
HPI Stampede is offline   Reply With Quote
Old 06-07-2005, 10:12 AM   #8
TXT all the way i run kongs and have never broke any tranny gears
1beatjeep is offline   Reply With Quote
