02-14-2008, 06:57 PM | #1 |
Pebble Pounder Join Date: Jul 2004 Location: College Station
| Narrower or Wider track width for 2.2 comp rigs?
I know this is more a opinion than right/wrong. I'm about to order some new beadlocks for my comp rig. Its a droop blackjack with axial axles and i plan on using masher tires. Would yall like to go wider or narrower? I know wider would obviously make it more stable, but narrower makes it that much easier to get into gates. Thx |
02-14-2008, 07:03 PM | #2 |
I like my rigs at 10" front and 9.5" rear, and I run sprung. Your droop setup will make the truck more stable anyway, as the CG is lower.
02-14-2008, 07:11 PM | #3 |
I like my rigs narrow. Wide is just more rig to get threw the gate. I also like the rear narrower than the front for the same reason it seems to track threw the gate better.
02-14-2008, 09:42 PM | #4 |
Nor-CalRCRC Join Date: Dec 2006 Location: Monterey Peninsula
Another benefit of a narrow rig is axle clearance. Since the tires are closer together and closer to the diff you will have more clearance when straddling a rounded section or hump.
02-15-2008, 12:40 AM | #5 |
RCC Addict Join Date: Jun 2004 Location: ORegon
narrow for all the reasons stated.
02-15-2008, 10:18 AM | #6 |
Rock Crawler Join Date: Dec 2006 Location: Southern California
I also run a narrower track in the rear it gives you a tigher turning radius! but shhhhhhhh!! don't tell anyone!!! -Marcos- |
02-15-2008, 10:33 AM | #7 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I run my BJ about 1/2" wider in the front.
02-15-2008, 11:49 AM | #8 |
I used to run 1/2" wideners on the front of my TLT axles and the 1/4" wider CVD hexes on the rear when I ran Moabs. I have always loved this setup. Right now I am trying 1/4" wider CVD hexes all the way around. This seems to work better with the shorter Losi Claws. I will then be trying the 1/4" wider front and no wideners in the rear next. |
02-15-2008, 11:51 AM | #9 |
02-15-2008, 11:55 AM | #10 |
02-15-2008, 11:56 AM | #11 |
