Thread: stall angle?
Old 06-17-2005, 05:41 AM   #1
Default stall angle?
just wondering:
what's the greatest slope your rigs will scale before losing traction? my BLT-8 will go right up a 68 degree slope, but loses traction at 70 degrees. (this measured with some old bits of curb a little longer than the truck and a builder's triangle).
as there's not a big crawling community here in Cleveland, i have no basis for comparison. is 68 degrees good?
microgoat is offline   Reply With Quote
Old 06-17-2005, 07:27 AM   #2
rbgerrish's Avatar
Not all surfaces are alike. A truck could climb 68 degrees on on type and not make 45 degrees on another type. Hard to say what my trucks will climb without some kind of benchmark 'climb test' that is the same for everyone. (like an RTI but for hill climbing)...
68 degrees is very impressive! Got any vid?
RYAn
rbgerrish is offline   Reply With Quote
Old 06-17-2005, 07:29 AM   #3
rbgerrish's Avatar
PS: Switch to Mashers 2000's, and you'll gain a few more degrees... For real!
Old 06-17-2005, 07:36 AM   #4
Yep, depebds on the terrain and tires. At Hamburger Hill, Utah we drove up 75 degree inclines durring the rain and snow. Well, those of us with pro-lines did.
utbeamer is offline   Reply With Quote
Old 06-17-2005, 08:04 AM   #5
i'm using busted up concrete curbs, kind of a rough surface. cutting the Dawgs got me 5 degrees, i'm hoping the new Moabs will do even better. we'll see when they get here. sorry no video but i could put up pics later tonite
Old 06-17-2005, 10:45 AM   #6
MODERATOR™
EeePee's Avatar
Bring that thing down to Columbus and we'll try it out!
EeePee is offline   Reply With Quote
Old 06-17-2005, 10:56 AM   #7
I don`t know about when the tires are spinning, but now that my X Factor has the rear extended to a 15 1/2 inch WB I can lift the front to almost vertical with the stock tires so I`m guessing that with the tires going it could go to around the 75 degree mark :neutral: . I am going to get swamp kongs so It will probably change a lot when I do that.
RampageFSJ is offline   Reply With Quote
Old 06-17-2005, 12:07 PM   #8
well up a big slope i'd have to say around 80* but i also have my crawler really low cause i like hill climbs. Also don't know if it counts but I have also crawled up an undercut so thats past vert maybe 105*. Just some advice for hill climbs, loose or not. Keep it full throttle all the way up, you want to keep you tires spinning, because the second the rear grabs, it will flip you over backwards. Only get off the throttle if forward progress stops.
moonbuggy is offline   Reply With Quote
Old 06-17-2005, 12:47 PM   #9
bendforthebone
My truck can climb up the side of my stucko house. But when the rear wheels hit the bottom it won't go up, but it will stay balanced there at a 90 degree angle
badtodabone is offline   Reply With Quote
Old 06-17-2005, 03:22 PM   #10
Is 75 degrees any good for a nitro?
Old 06-17-2005, 03:41 PM   #11
i think just about anyone's rig (here) will do that. i'm wondering about the slope it will actually climb, i.e. all 4 wheels on the inclined surface.
[QUOTE=moonbuggy]Also don't know if it counts but I have also crawled up an undercut so thats past vert maybe 105*.
i'd like to see that. (i'm not saying BS, i'm saying that's hella cool) that's a real good trick. this is the "scientific slope" i'm using:
i'll do another test on plywood and see how much difference there is
Old 06-17-2005, 04:12 PM   #12
Originally Posted by microgoat
i meant i could climb a big hill maybe 80* like something the length of the truck or more, this undercut was small, no way could any truck be upside-down and keep going.
Old 06-17-2005, 05:31 PM   #13
maybe if the body dragged on the ground and kept it from going over just long enough for the front wheels to snag, it could happen. but you'd never get it on video, that'd be a once-in-a-lifetime crawling event.
80* is pretty damn good, tho.
Old 06-17-2005, 06:35 PM   #14
i can crawl up a vertical surface about 16-17 inches and go over it
firstumustcrawl is offline   Reply With Quote
Old 06-17-2005, 08:10 PM   #15
Colt Python/SR9c
TwistedCreations's Avatar
well as mentioned, it depends on the terrain. some places my truck won't climb a 45* hill but yet i can bring it in and it climb up a 17" 90* couch. so it just depends on terrain
TwistedCreations is offline   Reply With Quote
Old 06-18-2005, 11:27 AM   #16
I can drive on a very vertical surface, with my nose pointed down .... as many have seen in THIS VIDEO.
All surfaces are different, tire compounds are different, layout of a truck is different from one to another, driver skill is different between eachother.... way too many factors to consider.
toyofast is offline   Reply With Quote
Old 06-18-2005, 01:24 PM   #17
slugzracing's Avatar
65*? PFFT pansy. My clod walks up anything!
Yes I drove it over this rock
slugzracing is offline   Reply With Quote
Old 06-18-2005, 02:35 PM   #18
You winched it didn`t you, that`s why the bag is there.
Old 06-18-2005, 02:40 PM   #19
i would love to see a video on that clod going over that rock, not saying that you are BS'ing but that is some hell of an incline
racecarking123 is offline   Reply With Quote
Old 06-18-2005, 02:49 PM   #20
Colt Python/SR9c
i would have to call BS on that one also. if you look close, there is more weight on the front and the rearend looks like its in the air
