06-21-2005, 04:31 PM | #21 | |
Pebble Pounder Join Date: Jun 2004 Location: burton
06-21-2005, 04:38 PM | #22 | |
I can pull my self with it hocked up to a skate board. | |
06-21-2005, 05:06 PM | #23 |
Pebble Pounder Join Date: Mar 2005 Location: Ulysses (In my hick town)
My plans are: Swamp Kongs on Mad Force rims 52 tooth spur gear xtm mammoth steering servo keep the stock 24.7 engine lock diffs (duh ) pull and shoot R box I`ve done: 15 1/2 inch WB stretch in the rear to fit a Revo shaft Stock specs says that it weighs 13 lbs. I`ll weigh it when it`s done. And I`d do your test if I could skate . Last edited by RampageFSJ; 06-21-2005 at 05:13 PM. |
06-21-2005, 05:30 PM | #24 | |
06-21-2005, 05:42 PM | #25 |
I`ll do you one better, once my X Factor is done, I`ll try to pull my spare 14 bolt around .
06-21-2005, 11:04 PM | #26 |
How about this? Which truck do you guys think would win between these two trucks? Granted, we are probably too far away from one another to try it for real. But I`d like to see the results of this if you would. Edit:I mean after mine`s done. Last edited by RampageFSJ; 06-21-2005 at 11:19 PM. |
06-22-2005, 07:53 AM | #27 | |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
06-22-2005, 12:13 PM | #28 |
Mine ain`t done yet so pics would be very hard to come by but you should be able to almost get a picture in your mind of mine. It`s an X Factor that will have the mods that I explained a while back. I`m also going to keep the stock tires and sipe out the line going down the middle and use them for major crawling since they are soft little buggers and the Kongs for anything else.
06-22-2005, 05:30 PM | #29 |
here is mine http://tinypic.com/687tqq.jpg |
06-23-2005, 08:45 AM | #30 |
What? Nobody interested?
