Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Tubers & Roll-Overs
Old 03-31-2008, 06:09 PM   #1
K_Willis's Avatar
Default Tubers & Roll-Overs
I've just built my first tuber rig, and absolutely love it... I always hated hacking my pretty new painted bodies up for tire clearance and I just love the look and compactness of a well built tuber...
After spending a week or two driving the thing, I'm having an issue, and I'm wondering how the rest of you that build and drive tubers deal with it it...
With my bodied rigs, If I'd roll, it was usually a 50/50 shot that I would get back on my wheels again... But with my tuber, it seems like I am lucky if I make it back to my wheels 20% of the time... Anyone else experience this? anything in the tuber design that might help with this?
Discuss...
K_Willis is online now   Reply With Quote
Old 03-31-2008, 06:28 PM   #2
It's all in the design. If you have a raised cab and narrow roof your percentage will go up.
phishead1101 is offline   Reply With Quote
Old 03-31-2008, 06:31 PM   #3
I try to remedy this by creating slight curves or having the top to be at a Point, to where it would either teater towards the front or the back. Having the angles point towards the tires if possible. I also try to keep the roof area as narrow and low as possible.
But in the end I'm working with what the customer wants it to look like.
But I think in general a tuber is going to have less of a chance at recovery.
Double J is offline   Reply With Quote
Old 03-31-2008, 06:42 PM   #4
bah... just shape them like this:
rolls over nicely.
p!nK
mrpink is offline   Reply With Quote
Old 03-31-2008, 06:43 PM   #5
TEAM MODERATOR
EeePee's Avatar
Originally Posted by mrpink View Post
rolls over nicely.
You can definitely attest to that.
EeePee is online now   Reply With Quote
Old 03-31-2008, 07:06 PM   #6
That can be one problem with the tubers,Ive thought about putting a bar on top that kinda sticks up to help roll overs but never have,i just deal with it.
rockmike is offline   Reply With Quote
Old 04-02-2008, 04:03 PM   #7
Prick
rambuller84's Avatar
I just try not to roll it over... DUH...
rambuller84 is offline   Reply With Quote
Old 04-03-2008, 01:23 AM   #8
MWRCA'er
Mnster's Avatar
Yeah you should see mine, I have no chance of rolling it back over. When it rolls it rolls right over on the roof and sits there wigging with all 4 tires off the ground. I'm redesigning it this year just for that very reason. I've played out some ideas and the best idea to me seems to be tall narrow roof as then it will only flop.
Mnster is offline   Reply With Quote
Old 04-03-2008, 01:33 AM   #9
Kamikaze's Avatar
I design all of mine to drive upside down on the front tires.......
Kamikaze is offline   Reply With Quote
Old 04-03-2008, 01:48 AM   #10
Rockcrawler's Avatar
With a 21" WB....at least one tire is going to touch the ground.
Rockcrawler is offline   Reply With Quote
Old 04-03-2008, 01:20 PM   #11
K_Willis's Avatar
Mine is pretty darn close to this, on 5.5 inch tall tires... But minimum tuber height is 3.75 inches, so if the height of the roof is even with tops of the tires, that gives me only 2.25 inches of belly clearance...
This isn't really feasible for a 2.2 on 5 inch tires, but for sure my super will be designed this way...
Old 04-03-2008, 02:38 PM   #12
Kamikaze's Avatar
The key is to make the front tires tought the ground instead of the whole chassis making all 4 tires rest in the air. By raising hte roof in the back and having a shorter front you can make a chassis that will come to rest with the front tires touching the ground. Then you have a chance at flipping it back over.
Old 04-03-2008, 02:45 PM   #13
K_Willis's Avatar
Ah, sorry, I misunderstood, and thought you meant that it could drive upside down on all fours... My bad, now that I read your post again, I got it...
Old 04-03-2008, 03:10 PM   #14
You may not have understood correctly, but that would be really fun to watch....
Mortimer Snerd is offline   Reply With Quote
Old 04-03-2008, 03:30 PM   #15
Just got mine in today, and I love it design is great. Good job MR.Pink
rolls over nicely.
p!nK
rckcrawler is offline   Reply With Quote
Old 04-04-2008, 02:07 AM   #16
Prick
The first tuber i built would almost always flop over on it's side but I could never get it back over on the wheels. The one I just built Tuesday has a TALL roof and it shouldn't be a problem once I get it done.
Old 04-06-2008, 05:08 AM   #17
MWRCA'er
Mnster's Avatar
So what is the consensus opinion here on the best way to build a chassis to roll back?
Tall roof front tires closer to ground on rollover. Truck should have the tendency to flop rather then roof roll.
Low roof tires in general closer to the ground. Should have a greater tendency to roll over on the roof when it goes over.
Old 04-06-2008, 07:12 AM   #18
I think a taller roof thats round would help. But I really think it's more then just that. I think it's mostly technique. As you see the front tires pulling of the rock and now they won't come back down. Nail the throttle till your back on all 4 and quickly let of the throttle to stop. As long as you can get the front tires to hit the ground during a roll over you have a chance. Once those front tires hit the ground you want has much wheel speed (Throttle Forward) to keep your momentum.
Old 04-06-2008, 08:34 AM   #19
my Gopher tube chassis does the same thing. But I have found some cool logs that if I hammer the throttle it will do a backflip. In mid air!
Toph is offline   Reply With Quote
