| | #1 |
| Rock Crawler Join Date: Apr 2007 Location: Denverish
| I'm putting together a plastic order from a local place and wanted to get suggestions from you all re: what the best plastic for links and a skid are. I'm looking for something ridgid and slippery that will do a good job of sliding over rocks and be reasonably easy to work with. I'm inclined towards Delrin (acetal), but wasn't sure if there was anything else I should be looking at. Any ideas? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Nov 2007 Location: Bozeman, MT
| I've tried several - PVC, acrylic, and a couple I can't recall - delrin is by far the best - it's strong and slippery and flex's a little for links. |
| | #3 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| Delrin is the best option. |
| | #4 |
| Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| | #5 |
| Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
| UHMW(ultra high molecular weight)plastic... yea ,really,thats the name thats what cutting board material really is "online metals.com" even has it in black! its also available from alot of woodworking stores like "rockler" i dont like actual cutting board matl. because it has a non slip texture on it i happen to come across a chunck 1' thick 2x3 feet! free!!! woodworker shops even have a peel n stick bout a 1/16 thick ....for links i avoid plastic n use hard chromed steel links with a combo of i think 8 different rod-ends n balls...each having there own intended use/location everything from revo push-rod ends to all those funky ones n the jato |
| | #6 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| I merged your threads because having two is not needed. |
| | #7 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| Acetal all the way..... |
| | #8 |
| Pebble Pounder Join Date: Feb 2007 Location: St.Marys County, MD
| Chalk another vote for delrin, make sure to get the cut of the marbeled stuff. It looks so trick compared to the black on everything else. |
| | #9 |
| Quarry Creeper Join Date: Nov 2006 Location: Reno
| I always use the UHMW plastic. I've been using it for years in my wood shop to make saw inserts and jigs and stuff like that and I love it. It can be planed or routed just like wood which allows you make almost any shape. It also holds threads like a ny-lock and is slicker than any other plastic I've ever felt. It makes awesome skids, but I've never tried to make links with it. |
| | #10 |
| RCC Addict ![]() Join Date: Jun 2007 Location: Waterford
| Delrin, Delrin, Delrin, acetal, Delrin is slick as snot on a door knob!! |
| | #11 |
| | #12 |
| Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
| Delrin i feel has to much flex for links ive run 4-40 rod through it to try to make it more ridged,it helped but i dont want my links flexing at all.Ive made my skids out of the uhmw and usually mill a spot in it so my trans sits as low as possible.Machined nice i spun the tool fast. Last edited by rockmike; 04-04-2008 at 06:59 PM. |
| | #13 |
| Quarry Creeper Join Date: Jan 2008 Location: marysville
| 6/6 Nylon is pretty bitchin stuff. It's hard and slick like Delrin, but wont get eaten up as easily Edit: McMaster has a nice Composite materials section that has all the info you'd ever need. See if that helps Last edited by BigRocks; 04-04-2008 at 11:49 PM. |
| | #14 |
| SD is the new JH ![]() Join Date: Feb 2008 Location: Driving my Corvette
| Delrin for skids and stainless tubing for links |
| Thread Tools | |
| Display Modes | |
