08-14-2005, 01:01 AM | #1 |
Newbie Join Date: Aug 2005 Location: PHOENIX
| Serviced Part's!!!!
Just wondering if PART'S are availible for up grade's or repair's????? HELP.....
08-14-2005, 01:17 AM | #2 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
well im not to sure on upgrades. im thinking that you will have to do most upgrading on your own. but i believe that they are going to strive for some the best customer service you will find. and as far as spares and repairs those are supposedly going to be available.
08-14-2005, 08:15 AM | #3 |
Rock Stacker Join Date: Aug 2005 Location: Ball Ground
| Partz
Yep, parts WILL be available and Arnie, the Prez of Nylint, absolutely commits to great customer service. As any company, they will have to make a judgment as to abuse or defect, but they really want to make you happy. To my knowledge, Nylint has no direct upgrades in the immediate plans. They ARE doing ongoing engineering to attack any weak points that might be found. |
08-14-2005, 11:57 AM | #4 | |
Quarry Creeper Join Date: Aug 2005 Location: Omaha
1. Upgrade the steering components. I ran mine for about an hour on what I would call moderate terrain - 6-8" river rock, a few larger boulders and some ledges about 12" tall. I didn't push it hard. (I do this with a real Rubicon and fully understand how not to push a rig beyond its limits yet make it perform beyond what people expect that it can do.) The steering did a lot of complaining and then just gave out. (See my post in the Breakage thread for more info.) 2. Drivetrain. The slipping drive belts seem to be a popular complaint/issue. 3. Wheel/axle setup. I saw several posts of people "blowing these up." Not sure what happened. I haven't had that problem. Basically, we're seeing the same failures on these rigs that you see in regular rock crawlers. If Nylint could upgrade the stock parts or offer upgrades in the aftermarket, I think this could be a truly great RC rig! | |
08-14-2005, 02:27 PM | #5 | |
COOL.. I was wondering also if this applies to 1/18 scale to cause i got one of those to and i play with more then the other...... I'm not looking to have part's replaced just part to have when do brake some thing, you know some thing i can go to the store for.... I have over 5 hour's play time with the 1/18 scale, and TRUST ME I PLAY HARD>>>>>> I'm starting to see the steering as one place I would like start after an half hour of play it seem's to need to be moving for it to turn right or left. Also would like to see bigger tire's and wheel's be availible for more ground clearance. | |
08-14-2005, 02:55 PM | #6 |
Newbie Join Date: Aug 2005 Location: My Castle
It seems as if they copied the samurai birfs.... I was backing mine up a ledge and had the wheels turned. The inner shaft "popped" out of the bucket and with a twist of the axle it distroyed the bucket. This also happended to my buddies... But his was the passenger side, so I am going to use parts from his to fix mine and hopefully they can figure out a fix for this... I have been taking a real close look at what caused the axle to pop out of the bucket and it seems like the steering needs some stops placed in there to keep it from turning so tight... When the wheel is turned full and you turn the axle it pops out without any kind of effort at all... I also have two of the 1/18th scales and my kids have been quite literally been beating the crap out of them and they have not even slowed down much less been a breakage. I will post pics in a few minutes under the breakage thread and show you what I mean... |
08-14-2005, 03:40 PM | #7 | |
Pebble Pounder Join Date: Aug 2005 Location: VT Burlinton
Stu | |
08-15-2005, 09:43 PM | #8 |
Rock Stacker Join Date: Aug 2005 Location: San Diego
Broke this little number....not so sweet for me, i hope they'll just send me the parts to fix it, after paint and shock mods i don't want to have to trade it in, DOH!! |
08-16-2005, 10:48 AM | #9 | |
stu | |
