| | #1 |
| Rock Stacker Join Date: Sep 2007 Location: Canada
| I was wondering if any of you guys have used an R2 HD. I need a beefy tranny cause the axial just doesnt cut it. I run a goat system right now, but I am gonna be putting in a mamba max and cobalt 7t. I was wondering that if I put a bigger pinion on it I could get decent wheelspeed for mud bogging. I have already toasted 4 output shafts and I am leary on just getting a beefy output shaft cause then I am gonna be wrecking gears. I kinda want my weakspot to be my driveshafts but I dont want them to be that weak. Also I was wondering if a maxx driveshaft is 5mm, and it has a pin that goes through the output and pinion instead of a set screw right? (its been awhile since I had a nitro) Any suggestions are welcome. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| TCS has metal gears for the Axial tranny. R2's haven't been the best trans, from gears stripping to bushings blowing. Atleast with the Axial you have a chance of picking up spares at the LHS. I haven't really seen anything about the HD version though, it may not be as problematic. |
| | #3 |
| I was just wondering about the r2 cause it can hang lower. My axial cant go lower cause the spur gear hits the frame, and my driveshaft angles are a little extreme. But thanks for the info I didnt catch those gears before. Last edited by Hellstomper; 04-06-2008 at 11:55 PM. Reason: spelling mistakes |
| Thread Tools | |
| Display Modes | |
