05-21-2008, 03:38 PM | #1 |
Pebble Pounder Join Date: Apr 2007 Location: at the bench of the up 'n coming '79 ford crew cab
| Driveshafts
Hey guys i have fianally twisted the driveshaft on my wheely king and i was wondering if it was possible to make axial driveshafts fit. would they slide on or not? i just ask because i like that there's a driveshaft container for the axial shafts. i was just wondering. thanks
05-21-2008, 03:51 PM | #2 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
FYI the axial driveshafts pop off really easy.And I think the Drive shaft rings are a waste of money. Just get pede shafts
05-21-2008, 04:03 PM | #3 |
Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
05-21-2008, 04:11 PM | #4 |
alrighty guys thanks for your suggestions. ill head on over tomorrow and get the job done right. thanks again!
05-21-2008, 04:13 PM | #5 |
oh and by chance would the pede shafts come with outputs to the axle? cause the ones on my current shafts are toast as well
05-21-2008, 04:32 PM | #6 |
Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
nope there seperate, shaft part #1951 or #1953 for a 6 pack, yolks #4628x for a pair
05-21-2008, 04:37 PM | #7 |
Newbie Join Date: Feb 2007 Location: Fargo
Definitely use pede or maxx shafts.
05-21-2008, 05:00 PM | #8 |
ok well cool. last question. i promise! would the maxx or pede yokes work on a wheely king axle output shaft?
05-22-2008, 10:23 AM | #9 | |
RCC Addict Join Date: Jan 2008 Location: Wetlands
It will not bolt on but you can drill out or axacto out the center of the yolk to make it fit. If you do this, use set screws on both sides of the yolk to help hold it onto the output shaft. If you are wanting to bullet proof your driveline, Go and check out rc4wd.com they have metal drive shafts to bolt on your tuck. Good luck | |
05-22-2008, 02:43 PM | #10 | |
alright! i guess i will support the vendors! thanks again fellas! | |
