Thread: Digging outside the box
Old 06-22-2008, 05:42 AM   #1
Default Digging outside the box
Well I wanted a dig really bad but couldn't afford to buy one so I started scrounging through my pile of junk and came across an old 3 speed tranny that was broke. I remembered that it had sliding colliers to shift gears and that gave me an idea.
first I gathered the parts from the tranny that I thought i would need
Here they are in the order i will be assembling them.
Now the idea is the center shaft will seperare the tranny from the drive shaft. The gear to the left will attach to the tranny and the gear to the right will be attached to the mount.
here is how it will work:
DS connected to tranny
Neutral
disconnected and rear locked
To start I tapped the first gear for 4-40 set screws
then attached it to the tranny
then i made a plate to hold the last gear. I made the hole small and pressed the gear into it then added a bit of solder to keep it tight
I then added the slider shaft
Here is the completed unit ready to go in
After a bit of adjustment I got it in and working great!
DS connected
Disconnected and locked
unfortunately I only have a 2 position switch on the controller so i don't have the option of neutral but if I feel I really need it I may mod the controller.
I hope this will give everyone another option for a dig set-up. it's compact, simple and works great!
Metal Masher is offline   Reply With Quote
Old 06-22-2008, 05:49 AM   #2
Wow, that's pretty nice, great job!
je1330 is offline   Reply With Quote
Old 06-22-2008, 06:14 AM   #3
you sir are a genius!
danielk is offline   Reply With Quote
Old 06-22-2008, 06:46 AM   #4
That is one of the best DIY digs I have seen, genius indeed
genki is offline   Reply With Quote
Old 06-22-2008, 07:06 AM   #5
Very creative,nice job man!
jhtoy is offline   Reply With Quote
Old 06-22-2008, 07:41 AM   #6
Just wow that's one of the best dig set up I've seen including the production ones. Keep us posted on how it holds up, I would love to make something similar to it.
Tupers is offline   Reply With Quote
Old 06-22-2008, 07:50 AM   #7
i am running a set up similar to that on my R2. ran it last season and won the series with the set up. i have no problems with it. i'll post up pics of mine to compare. nice job btw . if it performs just like mine, you're gonna love your's .
RydeFab is offline   Reply With Quote
Old 06-22-2008, 08:15 AM   #8
Location: Taylors Falls just hanging with the MNRCRC crew.
Very cool set up nice work man.
Stormin2u is offline   Reply With Quote
Old 06-22-2008, 05:50 PM   #9
Great idea. You have skill.
moparman is offline   Reply With Quote
Old 06-22-2008, 06:56 PM   #10
always innovative!! you come up with some great ideas!! and ability to bring them to life!!
NICE JOB!!
rockbound is offline   Reply With Quote
Old 06-22-2008, 07:02 PM   #11
great job!
ADDICT is offline   Reply With Quote
Old 06-22-2008, 07:07 PM   #12
666
MODERHATER™
666's Avatar
I thought I had seen something like this before....
New dig setup
666 is offline   Reply With Quote
Old 06-22-2008, 08:15 PM   #13
Very nice - looks like a factory setup.
Do you think durability will be an issue?
Mad Scientist is offline   Reply With Quote
Old 06-22-2008, 09:20 PM   #14
Thanks everyone!
New dig setup
That's not where i got the idea but I do remember that now that you pointed it out. Mine though is even more compact and much simpler.
Not really. Chino and RydeFab have obviously been using it since last year with no ill effects and judging by the comp i ran in today i should have no problems. The only glitch I had with it was that I forgot to loctite the set screws and the tranny gear backed out and wouldn't allow the collier to engage all the time but once i fixed that i really had no issues.
It does stick in the locked position when under stress however, but I may be able to take care of that with a stronger servo and a more solid servo mount.
Old 06-22-2008, 09:34 PM   #15
Im Brandon
Brandon's Avatar
Only thing Chino63 has to do is make sure to clean it, sand and dirt will really hurt that setup. However when its clean its flawless
Brandon is offline   Reply With Quote
Old 06-23-2008, 03:55 AM   #16
very nice
rckcrawler is offline   Reply With Quote
Old 06-23-2008, 09:26 PM   #17
It's nice to be able to dig into the old r/c junkyard and fab up something sweet like that. Nice dig!
sdmf7 is offline   Reply With Quote
Old 06-24-2008, 12:43 PM   #18
Nicely done there!
Just think, you could have bought one of the aftermarket ones like most of us and not only have many issues, but burn up servos and other fun things. I should go to momanddads and start rootin around for some old rigs.
Great idea!
O.C.D. is offline   Reply With Quote
Old 06-25-2008, 10:57 PM   #19
DISTURBIN' tha PEACE's Avatar
My boy Ryde also made me one. It worked horribly. It would always bind & never seem to want to disengauge the brake. With that many teeth holding on to the slding collar, I always needed to take a reverse.
He says he has no problems, but I have seen a few. Same as my problem. Granted he won the series, but it was not due to a flawless dig.
Keep it clean & lubed. And hope for the best.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 06-26-2008, 07:21 AM   #20
what car was that trans from?
jetboat is offline   Reply With Quote
