Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: how do you cut the treads on your tires???
Old 03-02-2004, 09:01 PM   #1
Default how do you cut the treads on your tires???
ive seen a lot of pics of your guy's rigs with custon cut treads.i was wondering what you use you cut them so clean.
lethe06 is offline   Reply With Quote
Old 03-02-2004, 09:11 PM   #2
Default Re: how do you cut the treads on your tires???
i used a pair of dynamite body schissors than evend itout with a dremel
firstumustcrawl is offline   Reply With Quote
Old 03-02-2004, 10:17 PM   #3
yep, you cut the big chunks off with scissors or side-cutters then use a dremel to remove the rest. takes alot of patience.
badhoopty is online now   Reply With Quote
Old 03-03-2004, 12:25 PM   #4
can you just use regular scissors? what kind of bit or grinding drum do you use to smooth it out?
Old 03-03-2004, 07:43 PM   #5
I like using body scissors because they seem to be really sharp and easy to get into the tread. I never sand my tires down, so I wouldn't know.
MaxxZilla is offline   Reply With Quote
Old 03-03-2004, 08:20 PM   #6
ill cut them down as far as i can with scissors and sand a little if i need too. does anyone have any suggestions on what type of pattern to cut out of savage tires?
Old 03-03-2004, 09:23 PM   #7
Take a look at the photo galleries on any and all crawler sites you know of, I am sure wou will find some cool idea's
rcwild is offline   Reply With Quote
Old 03-04-2004, 06:58 AM   #8
Nomercy's Avatar
im new to the crawling world also, but with a savage tire id just try cuttin gth efoams in half and go form there, they are a pretty soft tire as it is. and the tread flexes a lot on them any way. just my tow pennies.
Nomercy is offline   Reply With Quote
Old 03-04-2004, 01:53 PM   #9
Right. Use the Savage tires as they are. They work very well.....without foams.
DirkDigler is offline   Reply With Quote
