09-23-2008, 01:29 AM | #1 |
| HR Axle Swap on ARTR AX10
Finally Ran this rig today and realized I am past due on getting this info posted up on the Hot Racing Axles. During the initial run everything worked ok. Ran into some binding issues with the steering. Also had the front axle lock up completely on me more than once. Still need to look into that!! They are noisy without any grease in them, but that is to be expected from all metal gears. The factory clocked front axle is a nice touch. All the AX10 links clear the gear case and motor under full flex with hardly any space to spare. Test Rig: Axles: My quick fix for the upper link offset. I used some of the conical washers that are included in the servo mounting hardware. The shafts proved to have VERY tight tolerances with the bearings. I had to take them to the belt sander and take a few thousandths off to get the bearing to slide on. I love the clear gear cover Front and rear initial installation Last edited by Brandon; 09-23-2008 at 01:40 AM. |
09-23-2008, 01:33 AM | #2 |
TCS Order: HR Knuckles Integy 45t lathes Used some old Ofna shocks that matched the color scheme perfectly. They are still butter smooth too. Losi whites fit on them with a little work. Mayhem Eng offset wheels. HR Steering setup, and steering angle |
09-23-2008, 01:36 AM | #3 |
Rear lockout Initial Stance |
09-23-2008, 01:37 AM | #4 |
Battery tray and switch Dig |
09-23-2008, 01:52 AM | #5 |
Newbie Join Date: Jun 2008 Location: kona
nice build i like your battery tray with the dig swiches nice an clean |
09-23-2008, 09:01 AM | #6 |
Nice build, what is your width with those wheels? outer tire face to outer tire face? i got a hair under 10" with the Eritex wheels.
09-23-2008, 09:15 AM | #7 |
Newbie Join Date: Sep 2008 Location: Lost in Sin City
Looks great, now get out and scratch up some of that orange anodizing, Then report back on your test results |
09-23-2008, 10:32 AM | #8 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
Super Clean Build. I Like How Versatile These Axles Are. Hows It Perform?
09-23-2008, 10:33 AM | #9 |
09-23-2008, 03:27 PM | #10 | ||
I just received my East End Machining Delrin skid plate last week. I need to install it and get the lower links inboarded. Cant wait to get it on, its extremely nice and the few times I drove this rig with these axles I am getting hung up on the links mounted to the outside. Nice to be able to just buy the part to fix that | ||
09-23-2008, 03:47 PM | #11 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
So what are you doing with all the not used parts? Looks good though, love all the orange. |
09-25-2008, 01:46 AM | #12 |
Squeezed in a few quick runs this week. Here are the pics. Only carnage was an axle tube screw. Backed out and got chewed up in the gears pretty badly. The gears dont even have a scuff on them So remember, take apart the axles and loctite everything!! |
09-25-2008, 02:43 AM | #13 |
Newbie Join Date: Sep 2008 Location: chico,ca
that is pretty bling. so i have a question since i dont know almost jack about these things yet. do you have two steering knobs on the control and each sends a different signal (1 for front steering, 1 for rear) or are you just stuck with all time 4 wheel steering. ive thought about 4 wheel steer already when i want to build mine. edit: cancel that question. i just found a bunch of transmitter stuff on rear steer. im off to bed ive been on here way go long. Last edited by kiyul4130; 09-25-2008 at 02:55 AM. |
09-25-2008, 03:18 AM | #14 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
He has the rear locked out. Nluvwithxlr8ing, does the truck not act a little funny on the climbs with the rear sitting down like that? I know its not as bad since its not a shafty but wasn't sure if it affected it any. | |
09-25-2008, 06:45 AM | #15 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
Nice build and very clean. I am interested how these axles hold up but only time and beating will tell
09-25-2008, 11:31 PM | #16 | ||
They hold up pretty freakin well, I still cant believe the gears chewed up that 3mm screw without leaving a mark on them | ||
09-25-2008, 11:34 PM | #17 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
Nice Build Brandon. Still trying to hold back on the HR purchase though. |
09-26-2008, 12:01 AM | #18 | |
It looks like it would be about perfect for some straight links in the rear and would give a little better coverage of the motor. Looks great by the way. | |
09-26-2008, 12:06 AM | #19 |
I wanna be Dave Join Date: Sep 2005 Location: *
How loud are they compared to the bergs???
09-26-2008, 12:27 AM | #20 | |
They are loud, but so are my bergs, I have heard some silent berg axles and the HR axles are nowhere near that. Might be the grease though? | |
