08-15-2005, 07:51 PM | #1 |
Moderator Join Date: Jan 2004 Location: chicago
| need help fixing remote... throttle problems
eh, i dunno what you guys see in them. maybe i just dont have enough time with it. i painted the cage black, ( i got the jeep ) i got rid of the plastic tarp piece which imo makes it look 100x better. cut 4 coils from the springs, drilled out the hubs and mounted the front wheels on backwards. i took it out this weekend and messed around with it maybe 2 minutes before i put it aside... the response from the radio blows. i tried to 'feather' the throttle and half the time it had a mind of its own and stayed on for about a second or two after i let off the throttle. steering has the same issues. any fix for that other than upgrading the elecs? i can deal with on/off throttle and steering, but i want it to go on and off when i tell it to, not whenever it feels like it. |
08-15-2005, 08:42 PM | #2 |
Rock Stacker Join Date: Aug 2005 Location: Mesa
I think this has to do with the slider mechanism inside the controller. I took mine apart and stretched the tiny spring just a little to hold the contact tighter against the circuit board and it seems a lot better. Also make sure you are using a new battery in the controller. |
08-15-2005, 11:21 PM | #3 |
Pebble Pounder Join Date: May 2004
Someone was talking about putting different "micro" switches in the controller.
08-16-2005, 12:21 AM | #4 |
I mentioned changing out to microswitches.. I took my 1:18 controller apart and it literally has a peice of metal that slides back and forth for the throttle. The steering has a wire that touches two other wires for right and left. One could swap out these cheesy controls for something a little more robust like some microswitches, but it would take some work. |
08-16-2005, 08:28 AM | #5 |
sounds like an easy fix. thanks.
