08-17-2004, 07:56 AM | #1 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| What is the best way to link mount shocks?
What is the best way to link mount shocks so that they don't swing the links and make the whole truck loose?
08-17-2004, 09:20 AM | #2 |
| Re: What is the best way to link mount shocks?
Try mounting them like Pinchflat and Kaetwo do, with the shock "upside down". I tried it last night and it werks good. http://www.rccrawler.com/postt1694.html |
08-17-2004, 09:28 AM | #3 |
Do you guys just use cable clamps?
08-17-2004, 10:01 AM | #4 |
I am 99% sure that Kaetwo and Pinchflat use cable clamps; just like the Gecko uses. I have not run my truck with them yet but I did use just yer average cable clamp and saw a major reduction in flop last night while cycling the suspension on the workbench. |
08-24-2004, 09:22 AM | #5 |
Pebble Pounder Join Date: Apr 2004
what are cable clamps and how do u mount them on the links
08-24-2004, 02:35 PM | #6 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Cable clamps are little white plastic clamps that goes around the link and have a mounting hole for the shock. You can get them at a decent hardware store or RadioShack http://www.radioshack.com/product.as...t%5Fid=64-3028 I'm going to (again, hope you dont mind Grizzly) copy Grizzly's style of coil spring/shock setup, and use clamps to link mount either my savage shocks or my old maxx shocks. To hold the clamps to the links, I'm going to drill and tap a 3mm hole in the links and the clamps and run a short 3mm screw so that it can't move. |
08-25-2004, 12:15 AM | #7 |
Trapt, here are some pics of mine with cable clamps on the lower links. http://www.rccrawler.com/postt1956.html Adam, no I dont mind if you do a coil spring suspension. Imitation is the sincerest form of flattery right? I am sure you will like it. Just dont paint yer rig white with burple flames. Last edited by Grizzly4x4; 02-07-2008 at 10:29 AM. |
06-27-2005, 02:37 PM | #8 |
Newbie Join Date: Jun 2005 Location: vancouver canada
I want to revive this thread because the links no longer work..but I'd like to see pics of these clamps, (anyone have any pics) I'm having issues with my truck feeling very unstable My shocks are connected right to the links Thanks for your info |
06-27-2005, 03:51 PM | #9 | |
Quarry Creeper Join Date: Feb 2005 Location: fresno
yeah mee tooo, any pics and more indepth info would be much appreashedated | |
06-27-2005, 04:50 PM | #10 |
Quarry Creeper Join Date: Mar 2005 Location: Pleasant Grove
The plastic ones break fairly often. You can get metal ones at hardware stores. I found them at ACE.
06-28-2005, 12:09 AM | #11 | |
Any links or pics? Thanks | |
08-05-2005, 04:39 AM | #12 |
Pebble Pounder Join Date: Jul 2005 Location: Mesa, arizona
can we please make it so the links work or some picutures.
08-05-2005, 02:38 PM | #13 |
Quarry Creeper Join Date: Jun 2005 Location: Flagstaff
I am also wonting to get some info on this. And I'm trying to find out what would be better: A) shocks mounted to links with a clamp. B) custom square links with a raised mounting hole. With option (B) I don't know if the shock will bind when articulating. I plan on mounting the shocks up side down. Give feed back & pics Please. Thanks in advance. Don |
08-05-2005, 03:31 PM | #14 |
Rock Crawler Join Date: Jan 2005 Location: and OR. if . . . . Gone Fishin :p :b :p
Here is what I have done. 1/4" Collars from Ace Hardware Store. Just under $2 a piece w/ set screws. If you look at them you'd think they would twist all over the place but they don't. I've seen some Custom Clamps that I would love to have but, they are at least 2x as much $$$ |
07-13-2006, 03:05 PM | #15 |
Pebble Pounder Join Date: Feb 2006 Location: In a rock crawler down by the river
To keep cable clamps from slipping on the links I use a thin strip of 600 grit sand paper doubled over the link so the grit is in contact with the link and innner cable clamp surface. Never had one slip in this configuration.
08-25-2010, 08:10 AM | #16 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
What size cable clamp you guys using to do this?
08-25-2010, 09:46 AM | #17 |
08-25-2010, 10:01 AM | #18 | |
Maybe what I should ask is. What is he OD of a stock axial link? | |
08-25-2010, 10:38 AM | #19 |
08-25-2010, 10:49 AM | #20 | |
Axial links are 6mm diameter, or .23 inches. I'd try the 3/16" clamps, they should hold well. | |
