| | #1 |
| Quarry Creeper ![]() Join Date: Oct 2008 Location: Oakley
| I want to know what 1st and 2nd gear ratio people would want from a 2 speed tranny. The stock Axial trans has a ratio of 2.6:1 I have worked out the gears required to do a 1st gear of: 2.7:1 and 2nd gear: 1.8:1 none of the numbers include the reduction of the pinion & spur. Whats your thoughts? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
| the old emaxx trans has two stock ratios of 2.76, and 1.87 by the time you get one slow enough, the other is not fast enough. at least for me. I want something that will switch between 4 and 7.5 mph, not 4 and 5.5 mph which is about what I get out of the emaxxes in the shifting rigs I have. of course the case for it is huge, so if you have an axial doing the same thing it will at least be a shorter package and easier to fit in rigs. the next trick would be shifting it from the side instead of the end, so with a modified output shaft, you could hook a disconnect to it and have a high, low, 2wd, 4wd options for the scale guys Another issue would be sloppy shifting, the emaxx has a lot of rollback which is why you don't tend to see it is comp rigs in shifting form. Sounds like a good project though, keep us informed. |
| | #3 |
| I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| Now with the Summit out, maybe you could recase it's trans, like you did Axials? The Summit ratios seem to be pretty good. Yeah, yeah, I know it's an old thread, but a Summit trans case would be sweet. |
| | #4 |
| Chief of Slapaho tribe. ![]() Join Date: Aug 2008 Location: Slapaho, Hawaii
| Thread Tools | |
| Display Modes | |
