Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: How to SCORE a SERIES....
Old 10-31-2008, 07:03 PM   #1
1rcmonster's Avatar
Default How to SCORE a SERIES....
I have been wondering what is the best way to score a series. Should you just use the score from the drivers run? Tally them thru out the series of 4 or 5 comps, or should you just award 1 point to 1st, 2 points to 2nd and so on down the line???
Should all comps be set up so that there are the same amount of courses thru out the series?
If a competitor has an off day and does terribly at 1 comp but then turns it around next time what is the best method for scoring?
In my opinion I think all comps in a series should have the same number of courses. As far as totaling the score from the comps I believe it is best to award 1 point for 1st, 2 for 2nd and so on down the line.
Please give me your feedback on this subject....
1rcmonster is offline   Reply With Quote
Old 10-31-2008, 07:08 PM   #2
Team Nylint
redbaron's Avatar
SIRCC did 9 comps for 2008. You had to count 6 comps for the series. So if you ran all 9 comps, you threw out your worst 3 comps. You got points for your finish from each comp, total all your points from 6 comps at the end of the series and that's your series winner.
1st place finish = 10 Series points
2nd place finish = 9 Series points
3rd place finish = 8 Series points
4th place finish = 7 Series points
5th place finish = 6 Series points
6th place finish = 5 Series points
7th place finish = 4 Series points
8th place finish = 3 Series points
9th place finish = 2 Series points
10th place finish = 1 Series points
11th place finish = 0 Series points
12th place finish = 0 Series points
etc......
etc......
redbaron is online now   Reply With Quote
Old 10-31-2008, 07:45 PM   #3
Back in the WATER!
dpdsurf's Avatar
This is how Nor-Cal scores theirs.
- Series points will be given where first place will receive 250 points, second 245, third 240 and so on all the way to 50th place which will receive 5 points. Non series drivers will receive points for the event, but they will not be tallied in the final series standings. When tallying the series scores you'll receive points for the actual position you finish.
- The driver with the best score on each course will get 1 bonus series point.
- There are 8 events in the series. Only 7 will be scored for the series. This will allow you to drop your lowest score for the series if you attend all 8 events.
dpdsurf is offline   Reply With Quote
