08-20-2005, 11:56 AM | #1 |
Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
| custom trans idea,
Has anyone used two gd600s for a trans, two motors, one facing forward, the other back. it would be very low, small? i might try it on a tlt.
08-20-2005, 12:18 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: Central NY
are you going to use a spur gear too and have a shaft come from the spur?
08-20-2005, 12:32 PM | #3 |
probably not, just the motor, pinion, and the gd, i might have to put two to get enough reduction.
08-20-2005, 01:17 PM | #4 |
Pebble Pounder Join Date: Jun 2005 Location: Millerton, PA
Well, you might as well run 33/12.5/15 super swamper boggers then, you'll definitely have enough gear to turn 'em.
08-20-2005, 02:12 PM | #5 | |
Not too sure about being able to turn that much tire.... I had a hard enough time getting these suckers to roll with nearly 700:1 final crawl ratio | |
08-20-2005, 03:03 PM | #6 |
Pebble Pounder Join Date: Aug 2005 Location: Kenosha
HOLLY CRAP MAN. thats all i have to say
08-20-2005, 03:06 PM | #7 | |
RCC Addict Join Date: May 2005 Location: Auburn, WA
08-20-2005, 04:37 PM | #8 |
Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
I run 2 inline gds with a 2.5 to 1 t-case and its a perfect gear for my rig runing moabs. just watch your gear mesh cause the second gd is geting alot of torque and will strip if its not exact. the plactic also flexes under large loads throwing of the mesh causing it to strip. thats the only downfall to the set up. Plastic flex is why i ditched the pede tranny in favor of a custom t6 alu one. plus its just bad *** to run a alu t case with gear oil inside. |
08-22-2005, 12:06 AM | #9 | |
Newbie Join Date: Aug 2005 Location: over yonder
so did the tires actually turn or did the car just flip over backwards? | |
08-22-2005, 12:09 AM | #10 |
The trucks rear tires are sitting on the inside of the quad wheel, it was a joke.
08-23-2005, 03:06 AM | #11 |
Quarry Creeper Join Date: Dec 2004 Location: Tampa, Fl
Doh. LMAO Give us some pics of your setup when done.
08-24-2005, 03:37 PM | #12 |
RCC Addict Join Date: Jun 2004 Location: ORegon
why not use a long 3mm screw to thread all the way through the plastic posts on the gd and then top them off with a nut on the end. That might help stiffin them up.
